White Smoke on Start up? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 09-28-2008, 06:30 PM Thread Starter
Hey guys, ever since I got back from a road trip to Oklahoma towing a 4 horse goose neck, I have noticed that my truck gives a little puff of white smoke on start up. This wasn't the first time towing, it was just after this trip. Truck has 18,500 on it and it is completely stock except for the 4 inch straight pipe.
07 Red F-250 CC SB PowerStrokeDiesel
4 inch MBRP turbo back....no muffler, no cat
33 inch Pro Comp All Terrains
Texas Ranger CB Radio
07psd356 is offline
post #2 of 30 Old 09-28-2008, 06:32 PM
a truck
Matt P's Avatar
Normally white smoke on start up is glow plugs going bad
03 king ranch w/ a cummins
Matt P is offline
post #3 of 30 Old 09-28-2008, 06:34 PM
Early signs of EGR cooler going out, water in fuel, unburnt fuel, or bad glow plugs is what I think could be causing this.
2005F250 is offline
post #4 of 30 Old 09-29-2008, 04:04 AM Thread Starter
Damn, I knew it was something not fun. I know there's no water in the fuel, because I've ran through about six tanks since then.
07psd356 is offline
post #5 of 30 Old 09-29-2008, 04:10 AM
Raging Lunatic
choctaw's Avatar
I believe they have a flash to fix this condition.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #6 of 30 Old 09-29-2008, 04:12 AM
ADMIN AND TECH
SCUFFY828's Avatar
on a 6.0 i dont see it being glow plug issues they dont give many problems for that , im thinkin more along the lines of youust got back froma trip, and i have a feeling the egr valve is sticking open a little , that may sound crazy, but o a rip is when egr function is used the most , so it may be trying to stick, and has this truck been reprogrammed to the latest calibration, that will help also
ITS STOCK
SCUFFY828 is offline
post #7 of 30 Old 09-29-2008, 04:12 AM
ADMIN AND TECH
SCUFFY828's Avatar
thats what im thinkin
ITS STOCK
post #8 of 30 Old 09-29-2008, 05:49 PM Thread Starter
Last time the truck was in for service was in July I believe, but I don't remember them flashing it at all so probably not. Quick question, when does the EGR open and close? How does it know?
07psd356 is offline
post #9 of 30 Old 09-29-2008, 06:45 PM
Rice Hunter
Diesel Freak's Avatar
The EGR valve is always cycling open/ closed under pressure. It is pretty easy to pull out if ya wanna take a look at it yourself. Stump did an EGR valve write up some time ago.
I had my first EGR issue and Ford corrected it with flash. Each time you get flash ...... it is possible to loose some mpg. just my .02 worth
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #10 of 30 Old 09-30-2008, 03:42 PM
Powerstroke Techie
forddieseldoctor's Avatar
does your truck use any coolant?
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
