Transmission Filter pan gasket - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-23-2008, 05:29 AM Thread Starter
Does anyone know if the factory Motorcraft 5R110 transmission pan filter comes with a pan gasket and if not, whether the factory one is reusable? I'm going to be changing both filters as soon as mine come in later in the week and want to know whether I have to go to Ford and order the gasket too.
Anything special I need to know before swapping fluid and filters? Or is it similar to the way I did it in my F-150?
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #2 of 9 Old 09-23-2008, 05:38 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
the factory pan gasket is a reusable gasket.
I just check on this last night as i have to drop my pan and change the tranny temp sender in the valve body under the pan. They told me i do not need a pan gasket.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 9 Old 09-23-2008, 05:41 AM
KVFD
redstroker_2002's Avatar
your gasket is reusable. there is no need to replace it. If you do make sure its a ford reusable. otherwise it wont seal right and it will leak
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #4 of 9 Old 09-24-2008, 05:33 AM Thread Starter
Thanks. At least that's one part I don't have to buy. Man, they're proud of that Mercon SP stuff.
post #5 of 9 Old 09-24-2008, 06:06 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
How much is it? I'm going to drop my tranny pan this weekend and will have to buy more fluid but i haven't priced it yet.
post #6 of 9 Old 09-24-2008, 06:11 PM
Quoted: 2 Post(s)
I dunno my OEM one leaks and I have yet to change the fluid once, or even drop the pan........
Hoganshero is offline
post #7 of 9 Old 09-24-2008, 07:36 PM
Guys, I did mine to have a look in 06, and it is a really good re-usable gasket.
Look at the bolt holes to make sure nothing is over tightened or anything to crush it on re-use... The pan is only tin, and if the bolt holes are dimpled in just give them a light tap back out flat, so the bolts do not crush the gasket on re-use... Tighten lightly all the way around once at first, and then more firmly..
But I bought a spare and never used it on my 06 here in OZ...
Not likely to buy another spare one for my new 07 King Ranch FX/4 CC LWB F-350...
I went away, and did an 08 Silverado... Nice car, but light and tinny..
And now I am back home with an 07... The last of the Saddle Leather look King Ranch... Home to stay I think.. The new 6.4 has too much of everything and a bit gay of a maroon leather. An old horseman like me can't go past my new 07 King Ranch F-350 with only 10,000 miles on the clock..
Lone Ranger is offline
post #8 of 9 Old 09-24-2008, 08:28 PM Thread Starter
Most places seem to be at least 5 bucks a quart online. The dealer wanted 8 something. It takes something like 20 quarts, so that gets really expensive really fast. I've looked at all the auto parts stores online, and none list it for sale, but I might drive by tomorrow and see for sure. Advance stocks a lot of Motorcraft parts.
post #9 of 9 Old 09-25-2008, 05:46 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
You'll find that you don't need near that much when you change it. I bought 20 quarts and still have 6 bottles left. The torque converter and tranny cooler/plumbing is likely responsible for the other 6...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
