Add-a-Leafs - 2" to clear 35's
So I was on e-bay looking at add a leafs for my '03 6.0. One company is selling Pro-Comp long leaf add-a leafs for the rear for $79. + shipping.
Another is selling Rough Country 2" Add a leafs long leaf for the fronts for roughly the same cost. Is there any problems with either of these two companies - talking about the leaf companies - I know Pro-Comp is great with tires and suspension as is Rough Country for suspensions - Any issues would I face with simply installing the 2" leafs to my front and rear packs? Forgive the stupid question - will I need longer shocks? I have Rancho RS5000 on there now. Will I need steering adjustments or pitman arm or anything like that? The leafs intent for me is to clear for upcoming 35's and to increase weight and towing capability - Thanks |
I bought the rough country 2 inch leveling kit back before I had the lift. Fit 35's just fine and looks good and level. Worth it!
Did you notice it stifening the ride or anything adverse? I dont mind a stiff suspension - so that wont bother me. Was it as simple an install as it seems - unbolt u-bolts - slide new leaf - tighten u-bolts. Done?
The ride was the same, except for the tires. Just keep the axle down and the body jacked up then slide them in.
Anyone else - what shocks will I need or do you recommend, will I need anythign else?
Will it look stupid with 33's on there until I get my 35's? (their LT305/70R16E currently) |
Looking at tires again today - will 36.4" fit under my front with a 2" add-a-leaf kit?
I've got the Rough Country front leafs on mine and It clears my 255/70R22.5's (about36.6") with a little bit of rubbing on tight turns. Truck looks perfectly level with these
35's no bigger you will rub really badly. The 33's will look fine for awhile you might even like it more. I liked it. But 35's look really good
Thanks BigRick! I'll stick to 35's. Just need to get the leafs, get them installed - will I need new shocks? Or will my stock Rancho RS 5000's work for now?
It wouldn't be a bad idea, especially if you plan on any off-road. I haven't had any issues with my stock shocks but I stay on the highway mostly.
