04 6.0L Map sensor location
Where Is the map senspr on my 04 6.0L? And also, while im here, there has been a puddle of coolant on the garage floor under the truck for about 4 months now. When i first started to see it i tried to look where it was coming from and the motor looks dry. Sometimes the puddle dries up on the floor and then comes back so whatever is leaking isnt leaking all the time. Does anybody have any info on whats going on. Headgaskets? Thanks
the map sensor is located on the pasengers side of the engine compartment , just above the air box plenum
as far as your leak i bet the hose from the oil cooler to egr cooler is leaking they usually only leak cold , if its a orange hose it needs the updated hose which is blue, look right under the turbo and youll see it |
ok thanks for the help.
r map sensors hard to change? do you need to reset the computer in anything? or just change the part and thats it..
is it easy? |
Here is a picture of where the MAP is:
http://www.ford-trucks.com/forums/me...-dscf0001.html Here is the the EGR cooler hose: Center of picture, under the big blue CAC tube. http://http://www.ford-trucks.com/fo...ictureid=46344 Then looking straight down on EGR cooler hose: http://www.ford-trucks.com/forums/pi...ictureid=46345 |
