Modding the truck - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-17-2008, 07:48 PM Thread Starter
1QWK96GT's Avatar
Modding the truck
Hello everybody. I am going to be putting studs in my truck real soon. So I though what better time to delete the EGR. Well I got a hold of an EGR cooler and want to weld it up and install it on my truck. I plan on welding it just like this picture
My question is if I weld it up like in the picture and there is an internal coolant leak in the EGR cooler will it still operate properly? Will this solve any future EGR complications? Also the EGR cooler I got to modify from a buddy looks exactly like the one in the picture. Is the EGR on my 04 6.0 the same egr cooler pipe? Or is it a different style? What years did they use this style pipe on? Thanks all
1QWK96GT is offline
post #2 of 11 Old 09-17-2008, 07:52 PM
Send a message via AIM to Fireman5606
Here is a link to a complete write up on the EGR delete...done a little differently than what the picture shows.
Complete EGR removal write up
"When everything is said and done, there will always be more said than done." - unknown
"whether you believe you can or you can't, you are exactly right" - Henry Ford ____________________________________________
Kelly
94.5 Ext cab, LB 250, 4X4, 5 speed, Bone Stock
Fireman5606 is offline
post #3 of 11 Old 09-17-2008, 07:58 PM
If you aren't gonna re route the coolant line you run the risk of breaking the cooler inside the unit.
2005F250 is offline
post #4 of 11 Old 09-17-2008, 08:00 PM Thread Starter
1QWK96GT's Avatar
which coolant line? The one on the egr cooler? Which would be the orange line in the picture above? And route it from where to where? Thanks
1QWK96GT is offline
post #5 of 11 Old 09-17-2008, 08:03 PM
Rice Hunter
Diesel Freak's Avatar
YUP, and if ya break that cooler you chance washing out the oil cooler
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #6 of 11 Old 09-17-2008, 08:04 PM
Raging Lunatic
choctaw's Avatar
Fireman, tag me as slow, but your sig line is funny as all heck. Thanks
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #7 of 11 Old 09-17-2008, 08:04 PM
Check out the link I posted above (if you haven't already) The picture you are showing only blocks off the exhaust.( I think).the coolant can still flow through the cooler.
Kelly
post #8 of 11 Old 09-17-2008, 08:05 PM Thread Starter
1QWK96GT's Avatar
Would the coolant run in the cooler and back out even if there were a leak as long as the ends a welded up air tight? Sorry for so many questions I am new to all this.
1QWK96GT is offline
post #9 of 11 Old 09-17-2008, 08:06 PM
All in good fun, glad you got a laugh.
Kelly
post #10 of 11 Old 09-17-2008, 08:08 PM
Rice Hunter
That tube and hose is basically making a bypass back to the oil cooler.
Totally delete the EGR cooler. Block off hot exhaust gas at up pipe with freeze plug. Weld that plug in place!
Custom Tuned SCT
S.S. Brake Lines
ARP Head Studs
EGR Delete
'03 Turbo Swap
