In tank heater for stock fuel tank - Ford Powerstroke Diesel Forum
Old 09-16-2008, 11:19 AM
Is there such a thing available? I'd like to add a tank heater to my stock tank. I don't need to heat it to WVO temps but am looking at keeping Biodiesel from gelling. I only need to keep it up above 60 degrees or so. I'll also add a heated filter. Anybody done this?
Old 09-16-2008, 11:29 AM
I don't know nuttin....
Use one of these...
Old 09-16-2008, 11:30 AM
a 12V heater pad would have to be used while parked though...the hotfox only heats up after you have driven and the coolant reachees temp.
Old 09-17-2008, 09:27 AM
Thanks Clay. I was thinking that the Artic Fox wasn't really the solution to the problem. I really don't want to run a dual tank setup so I guess I'll have to really put my little pea brain to work and figure this out.
Old 01-03-2009, 02:31 PM
At what pressure does diesel ignite. just the #2 diesel that you get at any conventional pump.
And also if its possible with diesel, what temp "could" it ignite. just wondering.
