2005 Steering Box
I recently installed a dual steering stabilizer to help control some of my "steering" issues.
Now it's really tight, except when the wheels are turned forward - there seems to be 1-3" of play in either direction before anything moves. After further inspection, it seems like the bottom of my steering box has a bad bearing or something? I checked the bolts holding it onto the frame and they are all tight. So my question is, has anyone else had this problem? Is this something I can repair/rebuild, or do I need to get a new one. If I do need to purchase anew, does anyone have any recommendations on places to get them? Is a used one a viable option? Thanks. |
before I started replacing parts I would have someone sit in truck w/ running and in park wheels strait. Have them start rocking the steering wheel left to right enough to make the wheels start to turn. you should be inform of the truck watching the tie rod ends and drag link for play. you can also watch the steering box while your down there. Id hate to see you replace the steering box when all you need is tie rod ends or drag link ends.
Ggoodman,
Thanks for the reply. This is something I've already done and have narrowed it down to the steering box. |
Hent,
There is a TSB for that issue (#04-26-1) which call for a steering gear adjustment. Take the truck to your local dealer and have them fix it under warranty. |
i replaced mine...got it from orriely, it was like $175...but there was a $200 core charge. but it's not hard to change.
go to this web site, Sam's 4x4 Store, look up the AGR Rock Ram. spendy but works great. we can thank ford for poor design
jeff |
There is no "poor" design in SD steering boxes, gm and dodge both have more steering issues than ford, futhermore they all use similar boxes, but for 05+ ford increased the size of the steering sector shaft and other internal parts. the problem is big tires,and wide rims, and dropped pitman arms, all of which place more load on the box dual stabilizers are dampener for that increased load and vibration from the big tires etc. They do not cure any problems with steering play. It is unrealistic to expect a heavy truck with a thousand pound motor that gets driven like a sportscar/race truck/semi(come on we know how these trucks get used) not to suffer an occaisional failure. Dodge trucks have many aftermarket fixes to cure their steering shortcomings, sector shaft support bearings come imediatly to mind, and don't even start on the fixes for gm hd steering!
There is no need to speculate, this is a VERY common problem with '05 SDs which FMC is very much aware of. It is simply a steering gear mesh issue which was present right off the show room floor. Add in a few thousand miles of wear on the tie rod ends and the issue then becomes a real problem.
The truck has 91k on it. So, only under the Powerstroke warranty now. Will they still perform the work for free? |
