Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 09-05-2008, 10:52 AM
onecrazyblackredenck onecrazyblackredenck is offline
AC
I have an 03 6.0 and the ac works great when I am in the throttle or cruising the interstate, but if I am idling, it seems like there is no ac?????
Old 09-05-2008, 10:53 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
low on freon
Old 09-05-2008, 12:11 PM
jd4010 jd4010 is offline
My 2004 does exactly the same thing and the freon has been checked by Ford. I suspect that what's been happening - - when running highway, there is enough air flow in the engine compartment to keep things "cool". But when you stop and the heat of that diesel stays under that hood, it gets robs the a/c of capacity. I was considering the purchase of some additional heat shields to place around the fan, evaporator, etc.
Old 09-05-2008, 04:04 PM
tech10002 tech10002 is offline
It sounds like your fan clutch is getting flaky. Is the truck running hotter than normal when you're sitting still?
Old 09-05-2008, 06:49 PM
Adamvabeach Adamvabeach is offline
What about the heat? I noticed today when I tried to turn my defrost on with a lil heat it would not warm up. I set it all the way to 90 degrees and it was barely blowing warm. The AC works great but I have never had a problem with the heat before.
Old 09-05-2008, 08:00 PM
Have you changed the coolant recently? You could have an air pocket in the system. You could also have a malfunctioning heater valve. It blocks the flow of water when heat is not called for. Also, the damper door, damper vacuum motor, electronic controller, etc. could be malfunctioning. There's a lot of stuff to check. I wish I could be more help, but it's hard without being there. You just have to start eliminating problems until you find it.
Old 09-05-2008, 09:15 PM
Woa this is gonna suck but thank you very much. I may PM you for some additional ?'s if thats ok?
Old 09-06-2008, 02:47 PM
It's fine with me. Just keep in mind I'm not a super duty A/C expert. I'm a commercial refrigeration tech that just happens to have worked on a LOT of cars and trucks over the years. I can help with troubleshooting, but you're gonna need a service manual to sort out the wiring and vacuum routing.
