Glow plug wiring harness - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-08-2013, 08:48 AM Thread Starter
I am going to replace a couple of glow plugs on an '06 and seem to recall that Ford requires the harness to be changed out as well. I'm sure due to the current involved they want to make sure that the connector is perfect. Has anyone had problems after reconnecting the old harness.
gtwy is offline
post #2 of 12 Old 12-08-2013, 09:07 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
I would strongly recommend getting a new harness because you will most likely break the old one when you remove it. Also, it has o-rings around each plug of the harness that have to be replaced anyway otherwise you will probably see a small amount of oil leaking around each plug in the harness after you reconnect it.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 12 Old 12-08-2013, 09:11 AM
portcity_gt's Avatar
Quoted: 1213 Post(s)
Replace them, theyre only $40
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 12 Old 12-08-2013, 09:14 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
depending on the area your in and the miles on the truck you may be in for a real treat.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 12 Old 12-08-2013, 09:50 AM Thread Starter
Thanks for the replies. Curious as to where the leaking oil comes from?
gtwy is offline
post #6 of 12 Old 12-08-2013, 10:37 AM
I would highly recommend replacing the glow plug harness. They easily break if they've been in there for a while.
The_Auto_Tech is offline
post #7 of 12 Old 12-08-2013, 12:15 PM
The harness snaps into the side of the head above the exhaust. ...and theres oil in the head, if the harness is broken or not seated it will leak.
post #8 of 12 Old 12-08-2013, 12:39 PM
Why do you say that?
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 12 Old 12-08-2013, 01:11 PM
Quoted: 8 Post(s)
I think what he means is what I ran into. My truck came out of the North East and when I removed my glowplug harness, it broked off on two of the glowplugs. Not too big of issue since I was puling the valve cover to replace the gasket anyway, but to get the broken harness pieces off I had to pull the corresponding injectors.
73IH810 is offline
post #10 of 12 Old 12-08-2013, 01:13 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
well when every single exposed piece of the harness breaks off and you're left with a corroded brittle piece of plastic stuck in the rocker box you're not going to be having much fun.
