Need help ASAP - Ford Powerstroke Diesel Forum
Old 08-29-2008, 02:13 PM
Need help ASAP
Drag link end and inpection help. I think i need to replace mine and i'm supposed to be leaving tomorow i can fix thin i knoe i just need a little guidence. where can i get another end at what else do i need to inspect for more problems?
Old 08-29-2008, 02:17 PM
duct tape & zip ties
What makes you think it is bad or in need of being replaced. You can get a drag link at Autozone or other big autoparts store. But after replacing it you should have an alignment done.
Old 08-30-2008, 06:19 AM
the connection that connects to the Pitman arm is making a knock and alot of visual movement when you turn the wheel. the bolt is still secure in the pitman arm the movement is in the base where the stud is pressed into the drag link end. Why would i need an allignment this has no controll over pitch or camber of the wheels that would be the tie rod and cams right?
Old 08-30-2008, 06:25 AM
A full alignment would measure your camber, caster and toe. If you change the draglink and tighten everything up, you RISK the chance of your toe being off.
Old 08-30-2008, 02:52 PM
ok so where can i buy just the end for the drag link? the end that attches to the tie rod is fine and so is the bar. I see no point in replacing the entire thing.
Old 08-30-2008, 08:09 PM
You have to replace the whole bar .. should be at your auto parts store !
Old 08-31-2008, 06:50 AM
Not hardly, I figured it out they still call it a Tie rod end.
It's $33 from Power Stroke Shop. The Moog replacement part number is ES3427T. Just as soon as I get back home I'll get on it!
Old 08-31-2008, 09:30 AM
Unless there is a difference between the 04 and 06 there is no need for an alignment just because you replace the drag link. The toe is adjusted by a completely different bar. The worst that can happen is that your steering wheel is off and if you can replace the drag ling you can fix the steering wheel.
Old 08-31-2008, 09:33 AM
???? The tie rod does not connect to the pitman arm??
Old 08-31-2008, 09:35 AM
Why would anyone want to drive around with a "off centered" steering wheel?? ... yull need the alignment
