Engine Code P2262???
Well out of the blue just now my truck just threw this code. Anyone have an idea what it is??? I used my SCT to clear it and since then it hasn't came back? Weird...
ive heard that code is a manufacter code so i would ask your local Ford dealer. ive also heard it has something to do with your turbo.
Well, I cleared it and it seems to be running pretty good??? I've been babying her for awhile because of the cost of fuel. So after I cleared the code I did a little "driving like I stole her." LOL
ya that usually helps. i dont have a scanner on me and my shop i work at is closed or i would go up and look it up on mitchel to give you more details but it shouldn't be anything too bad!
We'll see if not oh well, that's what a warranty is for...lol
thank god for warranties
Well here's what I found on the net. No idea what all this means,,,,anyone???
P2262 C* Turbo/Super Charger Boost Pressure not Detected - Mechanical No boost pressure increase was detected. MAPhose, MAPsensor, CAC system leaks, Intake leaks, EP sensor, exhaust restriction. |
you may have a wiring problem
Hmmm, I why do you say that???
if its a pressure code from your turbo it may be the wire runnin back to your guage or the ground wire to the turbo to run the boost/pressure!
