35 X 12.50 on stock f-250
I was wondering if 35 x 12.50s would fit on my 2005 f-250 4x4 and if anyone would post up some pics id appreciate it thanks.
I want to know the same thing.
I had them on my truck with stock 20" wheels. Fit fine, looks GREAT. I had 35x12.50procomp Xtreme At's FYI. fuel mileage sucked. tires were to wide for the skinny factory wheel, so I had to run them at low pressures to get a nice wear pattern. If you go with aftermarket wheels & 35's that might change fitment, but allow you to run them at higher pressures giving better mileage. I have pics if need be... PM me your email address.
Check my sig these are 325/65/18 = 35x13.00x18 with a leveling kit. No rubbing with full turning radius
I wish mine didnt rub. I got 35 12.50 on a leveling kit and they rub. I see rims in the future.
36's or 37's will fit a 05 with no lift,...but you have to willing to do a little trimming
it will fit if you have the offroad package or a leveling kit
I've seen a few guys run 35/12.50s on stock wheels under a stock suspension.
Pretty tight though. For a 35/12.50 or 35/13 on aftermarket wheels I think you definitely need a leveling kit. I currently run a 325/60R18 (equiv 33/13R18) on 18x8.5" Welds under my stock height 07 and they are about as big as I think I can go to avoid rubbing while turning w/o doing any trimming. Gives the truck a nice stance since they are 2" wider than the stockers. Thinking about going to 325/65R18s (equiv 35/13R18) with a leveling kit next time around for a little better ground clearance. |
im running 35x13.50 mickey thomson claws on a stock 2000 f-250 and they dont rub at all.
Here's my truck with 325/65R18's on a 18X9 wheel with 4.5 backspacing and leveling kit
