vgt question - Ford Powerstroke Diesel Forum
Old 08-25-2008, 05:35 PM
vgt question
if i decide to unplug my vgt do i need to do it with the truck off or on or does it matter?* i would like to splice into the wiring to put a switch in the cab so i could turn it off and on when i please.** thanks
Old 08-26-2008, 08:27 AM
all opinions are appricated please thanks
Old 08-26-2008, 08:28 AM
say no to rolling coal
I don't think it will matter if its running or not.
Old 08-26-2008, 09:01 AM
and unplugging this helps out why?
Old 08-26-2008, 09:13 AM
I dont think will help anything, It will sound different, and will probably roal a lot of coal, but will run like sh!t
Old 08-26-2008, 10:30 AM
Unapologetically American
Feedback Score: 4 reviews
Probably to use is turbo as a 'jake brake', by opening the vanes when the go pedal isn't pressed. I have that in my aggresive tow tune from IDP, and it really works good when decending hills with a load.
Old 08-26-2008, 10:40 AM
Actually the reason some people put them on a switch or unplug them is they want to be able to roll coal for show. Your truck will run like chit when you unplug the vgt. Also if you do it much you run the risk of overboosting the charger under normal driving conditions.
Old 08-26-2008, 08:49 PM
The famous "smoke switch."
YouTube - smoke switch proof
Old 08-27-2008, 04:14 AM
I don't see the point
It doesn't make you go any faster, and just pisses the tree huggers off, and intrigues them to make more emission restrictive laws. My truck doesn't blow any smoke, and will still smoke most things on the road
Old 08-27-2008, 04:45 AM
ADMIN AND TECH
ill say ill agree with ya , i can see about the jake brake deal maybe , with it in the chp and tuned that way , to just wire it to a switch has to make it run like crap, check engine lights and i can see a overboost concern , but to each his own i guess
