idling - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-25-2008, 01:52 PM Thread Starter
onecrazyblackredenck's Avatar
idling
I have noticed in the last few weeks, sometimes my truck idles like it wants to die, seems like it will drop below 500 then jump back up where it is supposed to be. Is there a common issue with these truck that will cause this?? Also sometimes on start up, it seems like it has a hard time starting up. It runs really good other than that! Thanks in advance. Oh yeah I run diesel kleen ever fill up !
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #2 of 14 Old 08-25-2008, 01:57 PM
1995psd's Avatar
nada clue?
no mods besides strait pipe?
1995psd is offline
post #3 of 14 Old 08-25-2008, 02:01 PM Thread Starter
yep just strait pipe
post #4 of 14 Old 08-25-2008, 02:02 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Any codes?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 14 Old 08-25-2008, 02:03 PM Thread Starter
I am not sure, I will go check!
post #6 of 14 Old 08-25-2008, 02:17 PM Thread Starter
no codes found
post #7 of 14 Old 08-25-2008, 07:10 PM
What about cleaning your egr valve, if not that it could be an injector.
Big Mule is offline
post #8 of 14 Old 04-22-2009, 11:35 AM
smokersteve's Avatar
Quoted: 20 Post(s)
get a fuel additive in there, check the oil. if your running 4 your going to have a huge amount of soot build up. Are you using the low end responsiveness settings????
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #9 of 14 Old 04-29-2009, 10:08 AM
07powerstrokebosss's Avatar
my 07 had a similar issue and it turned out to be an injector
07powerstrokebosss is offline
post #10 of 14 Old 04-29-2009, 12:02 PM
Quoted: 20 Post(s)
check the airfilter
FICM Testing Videos
