up pipe mod - Ford Powerstroke Diesel Forum
Old 08-25-2008, 10:37 AM
up pipe mod
hey guys, i just bought a new 06 up pipe that im going to mod by cutting out the scoop and the y-pipe. what should i use as a patch panel to cover the new hole and what should i use as a plug to plug the egr cooler inlet? thanks for the help, john
Old 08-25-2008, 01:27 PM
Use the "T" that you cut off. Some stainless steel would make the best patch for the hole.
Old 08-25-2008, 03:28 PM
Is there a way to just remove the scoop from the OEM pipe and not have to patch it?
Old 08-26-2008, 03:24 AM
Yea...remove the pipe, cut out the scoop, weld a 1.5" plug inside the "T" and reinstall. This is reffered to as the "sneaky pipe" version since once you install it you can't visually tell the difference.
Old 08-26-2008, 04:59 AM
is it better to just cut out the "t" complete and patch it or can i get away with just cutting out the scoop and welding in a freeze plug?
Old 08-26-2008, 06:32 AM
From what I've read here and elsewhere, removing the connection to the EGR cooler leads to cracks in the flexible section of the up-pipe. I don't know if it's true or not, but to be on the safe side I would either....
(1) connect the stock up-pipe to the EGR cooler after blocking that port with a frost plug, or
(2) get a solid up-pipe (no flexible section) with the EGR tubing removed from some aftermarket vendor.
Old 08-26-2008, 06:43 AM
I've had the "sneaky pipe" installed for quite awhile now. No issues here. Do what is most convient for you either option will work great.
