Axle wrap on stock truck?
Just a thought here... how much axle wrap do stock 4x4's like mine have? And do they even make traction bars for a stock truck?
Yes, you can put traction bars on a stock truck....even a lowered truck for that matter.
As for how much you'll have will depend on your setup as far as how much power you are putting down and your tires. On my stock height 07, stock motor and 325mm wide tires I can feel a very small amount but not enough to cause any vibration or wheel hop. |
My 99 wont spin the tires without wheel hop. The good thing is these tires have lasted longer than any tires I have ever had before.
Another video showing traction bars (in this case One Up Offroad traction blocks) keeping the axle locked down and not allowing the pinion to climb the ring gear:
YouTube - Denny Hao Sled Pull - First Place FYI, Denny's truck is running a modified 5.9 CR Cummins with 40" Toyos under a 12-13" lift. |
OUO is top quality stuff
I'm bone stock in the tire & suspension dept. F250 stock blocks. Stock 20's and 275/65R20 GY ATS's. I'll have the girlfriend do a drive off while I watch.
