tire pressure & wear pattern (OEM 20's)
Finally got around to doing a wear pattern on the Factory 275/65R20E GY ATS on the OEM 20" wheels. Door jamb says 65psi cold all around. I tried that and got a pretty decent pattern. But I tried 70 up front and kept the rear at 65... much better I think. pattern looked real good. But I wouldn't go over 70 though. Thought I'd share my findings. 70/65 for me
nice job...it's always good to pass on good info
that's why I made this thread. http://www.powerstroke.org/forum/gen...nna-learn.html |
Yeah you compiled some good info. Riding empty.. you could easily drop the rears down to 60 and still have a good pattern. But up front I wouldn't want to go lower than 65, and no more than 70. so the factory placard of 65 all around is pretty good if you don't want to think about it. But in the name of saving $4.35/gal fuel, I'll be riding 70/65. Every bit helps... especially when it's a free mod.
max cold PSI on the OEM ATS's is 80psi. I'm going by wear pattern for typical driving load. 70/65 does it for me. I guess I could run 80 all around but that would wear the center of the tire faster...
if you run on straight roads and don't turn often it may. What i have found is that max inflation saves the edges from wearing out first on the curves giving a longer life to your tire. Remember, its the lugs on the edge that give you the traction in the dirt, mud so you want to keep them as sharp as possible. My last set of Bf's had 90,000 when i replaced them. That was five tires.
wow. 90k. Yeah I can see what you mean by turns wearing the edges. But on our suzuki cracker box it says 30 psi cold, and I've been running them at 33 cold for the past 20k. the centers are worn a lot worse then the edges. Flat out noticeable. so I'll give the 70/65 a try for a few thousand miles and go from there.
I actually found that gauge was reading low... so when it was reading 33, I probly had about 34 or 35 in there. Hence the 4-5 over the 30 placard and the center worn tires. a bit to much lol. and I never did a wear pattern on that lil car either. I check the air in our tires 1x/week religiously. And yes I've noticed the weahter fronts affect it. Now I own about 6 different high end gauges from a morroso to a pencil. OH well... plenty of gauges to go around.
