Anyone ever hauled a Yamaha Rhino in the bed? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-20-2008, 07:16 AM Thread Starter
Dan"gerous"'s Avatar
My Rhino weighs in at around 1,200 lbs. I'm not concerned about the truck hauling it, I'm concerned about the tailgate cables holding as I drive it up the ramps into the bed. Any idea's fella's? Also, the rear wheels will have to set on the tailgate at the hinge point. Not much pressure on the cables there but possibly at the hinges.......
05 F-250 6.0 Lariat, FX4, 4x4 Crew Cab, Torqshift, 3.73, Power Sun/Moon Roof, SS 4in Magnaflow Turbo Back w/cat delete, Zoodad, EGR delete w/FCPD UP pipe, SCT Xcal 3, HID Light Kit, 5w-40 Rotella T6, Century Fiberglass Cap
68 Ragtop Vette
03 Honda CBR1100XX BlackBird (180+ MPH)
05 Yamaha Warrior (snowmobile)
08 Yamaha FJR1300
09 VW Jetta TDI (50+MPG's)
11 Suzuki 750 King Quad
Dan"gerous" is offline
post #2 of 16 Old 08-20-2008, 07:17 AM
cchase's Avatar
i have put over a 1000 pounds of block on my tail gate, and nothing bad even looked like it was going to happen... but i cant tell you to do it, because i have never done it with a rhino
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 16 Old 08-20-2008, 07:30 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
I would of never guessed those things weighed that much... hmm. I don't know that I would like the idea of all that weight hanging on the tailgate. I don't doubt the calbe would hold it. My fear would be the end pieces letting go from the cable..
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #4 of 16 Old 08-20-2008, 07:35 AM
6.0Sean's Avatar
Send a message via AIM to 6.0Sean
I carry 2 full size harleys in the bed of my truck all the time (700-800 lbs each) and both rear wheels seem to always be sitting right in the middle of the tailgate. This has never been a problem with cables, but I do have a dent on the inside of tailgate from weight and hauling. I would think it would be better with a rhino though since the tires are wider.
2004 F-250 6.0
SCT running Extreme Street from Innovative, 4" straight pipe 6" tip, ISSPRO Pyro and Boost guages, Zoodad, Omega remote start, sirius radio
6.0Sean is offline
post #5 of 16 Old 08-20-2008, 07:43 AM
fordmugg's Avatar
i think it will be fine but you can get yourself two 10 ft 2x6 boards and line them in the bed so the tires are on them .....it will take alot of pressure off the tailgate because the boards will hold most of the weight
my name is jeff but my friends call me.........jeff
2003 f-250 6.0 lariat, crew cab, long bed,fx4
Autometer guages
Z plate Zoodad
4inch turbo back
s&b intake
Pro comp
8.5 inch lift
Dual shocks
toyo 37's
stereo System
100% awesome
fordmugg is offline
post #6 of 16 Old 08-20-2008, 07:48 AM
haters gonna hate 24/7.
blueovalman14's Avatar
a buddy of mine hauls his rhino around in the bed of his truck all the time..... he has an 08 gmc 1/2 ton truck
this is why i bought a 16' utility trailer for my 4 wheeler so i dont have to worry about it
2012 F-150 CC/SB 4x2 Lariat
2005 F-250 CC/LB 4x4 Lariat (Blue/Tan)- Traded In
2005 F-350 CC LB 4x4 Lariat (DSM/Tan) ---> RIP 7/16/2010 (Stolen)
1995 F-350 F-350 CC LB 4x4 XLT
Originally Posted by craftkr View Post
Maybe Choctaw will let you start the LSP Itty Bitty F1Fitty Daycare Chapter????
blueovalman14 is offline
post #7 of 16 Old 08-20-2008, 07:55 AM Thread Starter
I have a trailer also but won't be able to use it this time around because I'll be pulling a travel trailer. Guess maybe I should have gotten a 5th wheel.........I then could have pulled the rhino on it's trailer behind it. Good idea about the boards fordmugg.
68 Ragtop Vette
08 Yamaha FJR1300
post #8 of 16 Old 08-20-2008, 08:08 AM
Ole White
bigwhite7.3stroker's Avatar
I think you should be fine seen it done before
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #9 of 16 Old 08-20-2008, 08:17 AM
Raging Lunatic
choctaw's Avatar
Have you ever been to a NFL/NASCAR tailgate party? I think if it will support all that weight then you should have no problems.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #10 of 16 Old 08-20-2008, 09:18 AM
SuperStroked's Avatar
I have done it personally when i worked for Yamaha. Fits in there nice and snug. Take the tailgate straps and loop them over the latches that the tailgate hits on the bed and the tailgate will stay at an angle. This is only needed if you are hauling a trailer as well. Just gotta watch out for low clearances.
2005 F-250 CC FX4
SCT-Dyno Tuned by DJ/Gearhead/Innovative - Still running strong!!
14.41 in the 1/4 mile
4" MBRP / Volant Intake / Accufab / Autometer Gauges
Trusted Performance Stage 1 w/Crossover
Liberator Performance o-ringed heads
5.5" DR with 5" DR plush rides
1" CJC Traction Blocks
36" Mud Country's
SuperStroked is offline
