Front leafs on 05/07 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-12-2008, 01:55 PM Thread Starter
Lonno's Avatar
Does anyone know if you can put front leaf springs on a 05/07? Has the frame changed at all or have the spring mount locations been modified? Any help please.
Dave
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #2 of 12 Old 08-12-2008, 02:33 PM Thread Starter
Lonno's Avatar
bump. bump.
All Diesel
All Day
Lonno is offline
post #3 of 12 Old 08-12-2008, 02:34 PM
cj41foley's Avatar
You gonna put leaves on it and go on up in the air with it?
Jason
2006 F250 2wd 6.0 psd, 8.96 1/8th mile with canned SCT tunes, now running Spartan Hybrid Race tune! AFE Stage 2 PRO DRY S, 4" turbo back str8 pipe in front of rear tire, auto, crew cab short bed, ZOO DAD mod, 5% tint over the factory tint.
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
cj41foley is offline
post #4 of 12 Old 08-12-2008, 02:37 PM
Raul@Stealth Automotive's Avatar
**** man if your gonan go leafs ill trade ya lol.... im pretty sure its not gonna be a direct bolt on thing.... your gonna have to change your front axle to the 99-04 setup for the leafs... that and you will need to weld or drill in the hanger kits....
if you find a nice used setup or someone to split it with it shouldnt be too hard....
Raul@Stealth Automotive is offline
post #5 of 12 Old 08-12-2008, 02:48 PM
cj41foley's Avatar
change front axle? he doesn't have one, it's 2wd, if you know how to weld it wouldn't be hard to fab up some hangers and springs and just go ahead and put a dana 60 under that thing, add a transfer case and let it rip
Jason
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
post #6 of 12 Old 08-12-2008, 02:50 PM
oh snap it is... i didnt see that in his sig.... i had assumed he had a 4wd
post #7 of 12 Old 08-12-2008, 02:51 PM
Your truck ride too smooth for you?
bigd4x4 is offline
post #8 of 12 Old 08-12-2008, 03:57 PM Thread Starter
Lonno's Avatar
Lil project underway. So was that a yes on the leafs? Basically I just need to know if the leaf spring mounts are a direct bolt in. Did they change anything about where the mounts went in the later models?
All Diesel
All Day
Lonno is offline
post #9 of 12 Old 08-12-2008, 04:04 PM
im pretty sure they are not a direct bolt on
post #10 of 12 Old 08-12-2008, 07:07 PM
DCSpecial's Avatar
Not sure.
I know to convert a 99-04 to a 05+ front axle and suspension that you have to drill some holes in the frame. Never known anyone to go the opposite way.
I'd have to look at my 07 tomorrow to get a better idea.
Are you going 4x4 or just looking to go in the air?
DCSpecial is offline
