HPOP fitting repair time - Ford Powerstroke Diesel Forum
Old 08-12-2008, 12:54 PM
My truck died on the highway today, turns out to be a bad hpop fitting, just wondering if you guys had a guide that would say the labour time to change the fitting, dealer says its a 22 hour job, seems kinda long to me.
Old 08-12-2008, 12:55 PM
22 hour job? one of our work trucks had the whole thing replaced on a 7.3 in 3 hours
Old 08-12-2008, 01:18 PM
Desert Shield/Storm Vet
Are you out of warrenty?
Old 08-12-2008, 02:53 PM
Ford cancelled the warranty after the original engine in my truck was dusted.
Old 08-12-2008, 02:58 PM
DKR DKR is offline
<--Pro Cooler Racer
If it is the STC fitting that you are refering to, then it is less then 8 hours on the 6.0. I just had to have mine done by Ford. They diagnosed it one night, and had it fixed at the next shift. He didn't work on it the entire time either.
Old 08-12-2008, 03:18 PM
its about 6 hours and if your that far in it do a egr delete as well.
Old 08-12-2008, 05:29 PM
They said they had to change the branch pipe too. Told me they would have to pull the tranny and remove the rear engine cover to get at it.
Old 08-12-2008, 07:03 PM
they came out with a up grade kit for the hpop
Old 08-12-2008, 07:05 PM
Jon
Guest
Posts: n/a
Dang
Pretty rare to have one need the branch tube.
Old 08-12-2008, 07:16 PM
DKR DKR is offline
<--Pro Cooler Racer
I just read about that part today. And, yes it is pretty involved from the sounds of it.
