2003 6.0 - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-11-2008, 06:18 PM Thread Starter
I have a question and need some input. I was looking to buy a newer truck and ran across a 2003 6.o crew cab lariat at a great price,but have heard a lot of things about the first of these engines.Can someone help in the answer of buy or not to buy because of this engine? the truck has about 80000 miles on it and according to Ford has only been back in the shop a few times for warranty work.
jekl is offline
post #2 of 16 Old 08-11-2008, 06:24 PM
Id check the bell housing to the transmission for any oil residue. Other than that im no expert but if it has 80K on it a defect would have shown its self by now. The good side=The 03 6.0L has a 10 vane turbo rotor and whistles like a champ!!!!!
2005 F350 FX4 CC LB LARIAT 6.0L Diesel -SOLD
2012 F350 4X$ CC LB LARIAT 6.7L Scorpion
BLACK and ADOBE
RECON Lights
LEVELED.........My Black Stocky!!!!
Adamvabeach is offline
post #3 of 16 Old 08-11-2008, 06:28 PM
ADMIN AND TECH
SCUFFY828's Avatar
more than likely any problems the truck has had should have been taken care of, in my opinion and i work on these every day , i would own an early 03 model before an 04 or 05, i do less work on them than 04 mostly , but are not plagued with high pressure oil issues like the 05, ill break it down even more by year and problems
2003 - rear main seal leak , some injector issues,an icp sensor may crack and leak also , the updates from ford have made better
2004 - several different oil leaks , some injectors issues , egr valve problems , a wiring nightmare , turbo sticking , head gaskets, egr cooler
2005 - every problems 6.0 ever had is seen in an 05 model, wiring problems were less than o4 but i do more work on 05 models than any other
06 and 07 , seen some slight problems but not bad at all
ITS STOCK
SCUFFY828 is offline
post #4 of 16 Old 08-11-2008, 06:44 PM Thread Starter
The things that Ford did on this truck were replaced intercooler on passenger side,replaced egr and replaced an injector the rest was recall work.I'm was thinking like Scruffy that any defects should have showed by now.
jekl is offline
post #5 of 16 Old 08-11-2008, 06:46 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I also think that if anything was gonna show it would have already
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 16 Old 08-11-2008, 06:48 PM
fordmugg's Avatar
i have an 03 6.0 and its been great to me no problems ......i did however get an oil leak a week ago according to scuffy its prob my icp sensor leaking ....but other than that its been good
my name is jeff but my friends call me.........jeff
2003 f-250 6.0 lariat, crew cab, long bed,fx4
Autometer guages
Z plate Zoodad
4inch turbo back
s&b intake
Pro comp
8.5 inch lift
Dual shocks
toyo 37's
stereo System
100% awesome
fordmugg is offline
post #7 of 16 Old 08-12-2008, 04:56 AM
onecrazyblackredenck's Avatar
I just bought mine with 114000 on it and it seems to run excellent! only oil leak I see on mine is at the plug I figure when it is time to change the oil, ill replace the washer and it will be good as new.
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #8 of 16 Old 08-12-2008, 05:05 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
almost 100k miles on my 03 and no issues other than a leaking ICP.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #9 of 16 Old 08-12-2008, 11:58 AM
zspear1's Avatar
I have an 03 as well, good truck changed ICP and pigtail two weeks ago for a rough idle. Runs good I only have 57K on it though. I had a surging issue till I plugged the EGR flow. Other than those two, no issues.
2006 crew cab XLT, Fx4 6.0 stroke, torqe shift trans, deleted EGR, Turn over ball GN.
zspear1 is offline
post #10 of 16 Old 08-12-2008, 03:56 PM
Saber123316's Avatar
I had some smoking issues with mine do to carbon build up a good few romps on the gas and some diesel conditioner and she works like new no smoke.
2003 F-250 s/c s/b 6.0 Powerstroke diesel 4x4. 4 inch Magnaflow Exhaust AFE stage 2 Intake Tuned by Eric at Innovative Diesel ARP Head Studs and EGR Block off
Saber123316 is offline
