how to get studs done? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-08-2008, 04:06 PM Thread Starter
jcmer22's Avatar
hey guys, my 06 has 61,000 miles on it and before its out of warranty i want to get the studs done. i want to have the dealer do gaskets and install the studs at the same time. can some of you tell me exactly what you told the dealer to convince them to do gaskets and install the arp studs. thanks in advance. john
jcmer22 is offline
post #2 of 14 Old 08-08-2008, 04:46 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Wish I could help ya, but mine was a family connection. They did it as a favor.
Some guys from here just flat out ask the dealer. It is usually a lot easier if you are having problems or sympoms of a problem. Most dealers won't do them, just to do them. For instance, even with my connection, I still had to wait for symptoms.
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #3 of 14 Old 08-08-2008, 07:46 PM
06ARMADILLO's Avatar
Send a message via Yahoo to 06ARMADILLO
I need mine done too. I have 86,XXX miles now and don't want any problems after the warranty. I have a friend that will do mine on warranty in Miami, but that is a DRIVE. A serious drive. Guess I will have to bite the bullet and do it regardless....
*Also, what is the STC fitting? I was told mine needed that done.. Sorry to hijack..
2006 F250 Amarillo Edition. Crew Cab, SB, 4X4, 20" Wheel Upgrade, Sunroof, Full Alpine/Infinity Sound, Limo Tint 360*, Rhino Liner, Muffler MIA, Afe Stg 2 Intake, SCT with Spartan Hybrid RACE tune:burnout
Bully Dog OUTLOOK Monitor for sale!!
Check out
06ARMADILLO is offline
post #4 of 14 Old 08-08-2008, 07:49 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Part of the HPOP, get it done if they are doing it under warranty. Ford released a new modified "improvement". Mine had to be replaced (just this week @ 40,000mi) along with some other connectors. They went out causing my truck to die on the road (loss ICP) and a no-start situation.
Eric
Email:
DKR is offline
post #5 of 14 Old 08-08-2008, 07:52 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
undo the valve covers and loosen some head bolts. when you lift the heads, then go get it fixed. hehee
NOTE: This is a suggestion...not that I would do it if my truck was under warranty.......
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #6 of 14 Old 08-08-2008, 08:13 PM
Rice Hunter
Diesel Freak's Avatar
Most all these dealers are being watched under the careful eye of FOMOCO. I think they are getting smart on these mods. Can you imagine the warranty cost they have absorbed
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #7 of 14 Old 08-09-2008, 03:49 PM Thread Starter
jcmer22's Avatar
am i definetly going to have a head gasket problem in the future if i dont do the studs?
jcmer22 is offline
post #8 of 14 Old 08-09-2008, 04:17 PM
back in the saddle
shu873's Avatar
Probably someday yes in all likelyhood. Whether that's at 50k or 250k miles who knows?
nobody can give you a definate answer unfortunately, the old saying applies "if you want to play, you've got to be willing to pay".
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #9 of 14 Old 08-09-2008, 04:17 PM
AvroAero's Avatar
Not definately, but a high chance you'll do em at some point with the looney.
2004 Ford Excursion 6.0
-SCT livewire w/ innovative extreme tunes
-Banks monster exhaust
-Zoodad
-05 conversion w/ harley headlamps & HIDs
-Viper 5900 remotestart/alarm
-ARP studs
-EGR delete
-Defender roof rack with 600W of light
-whelen hideaway strobes
-Sound off Predator dual red-red
-Whelen 500 4 amber 2 blue
AvroAero is offline
post #10 of 14 Old 08-09-2008, 04:57 PM Thread Starter
jcmer22's Avatar
my problem is id like to find a way to do them under warranty somehow instead of it costing me a fortune later.
jcmer22 is offline
