A/C doesn't seem very cold - Ford Powerstroke Diesel Forum
Old 08-07-2008, 04:20 AM
Hi gang. I'm less than 1 week into the ownership of my first F250. I moved up from an 2002 F150 where the AC was so cold it would drive you crazy. With my new truck, it just doesn't seem very cold. The air isn't warm by any stretch, but it isn't freezing me out either. When I was driving it home, I had the temp set to 70, and the fan blew on high almost the entire trip home (300 miles of interstate). Do the A/Cs in these diesels just not work as well as the gassers, or could I have a low freon issue (or possibly worse). I'm taking her to the dealer tomorrow for a 60k service, so I'm planning on having them check it out, but just wanted to get some opinions before I showed up there.
Old 08-07-2008, 04:58 AM
Mine is the same way......Wish I had the solution..Maybe someone who does will share it!
Old 08-07-2008, 05:51 AM
ADMIN AND TECH
there is a bulletin out about not enough freon in these trucks from the factory
Old 08-07-2008, 02:21 PM
It could also be this ..................
TSB 08-13-5
Old 08-07-2008, 02:32 PM
wow, didn't know either of these issues. Low freon and a TSB about debre.
Old 08-07-2008, 02:40 PM
OK but when the truck is over the 3/36 and did not op for the extended plain the TSB are no good or will the dealers still fix it ?
41000 on my 06 F-350 FX4
Old 08-07-2008, 02:51 PM
Send a message via AIM to troid123
subscribing
Old 08-07-2008, 03:02 PM
scuffy, If we put a Temp gauge in the air vents, what temp is "good"? at what temp do we take it in?
Old 08-07-2008, 03:50 PM
I'm hoping it is the freon. The TSB about the debris sounds like the compressor and dryer have to be replaced....that doesn't sound in the same zip code as cheap. She goes in tomorrow AM for the service, I'll let you know the outcome.
Old 08-07-2008, 03:56 PM
No they wont. A tsb is a technical service bullitin. It explains common problems and solutions for vehicles. They have nothing to do with warranty unless theres a campaign or something.
