How to: 500hp - Ford Powerstroke Diesel Forum
post #1 of 66 Old 08-04-2008, 04:35 PM Thread Starter
jcmer22's Avatar
How to: 500hp
hey guys, with the mods that i have plus arp head studs and gauges what will it take to get to 500 rwhp? give me some ideas on what it would take to get close to that number. if it takes a new turbo and crazy other parts to get to 500, but only i few more things to get close like 475 id be more interested in getting close for less money. thanks for the help
jcmer22 is offline
post #2 of 66 Old 08-04-2008, 04:47 PM
International Threat
Marty's Avatar
190 cc injectors, 03 turbo, head studs, EGR delete, fuel system should get you pretty close, with some spray you should be there.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 66 Old 08-04-2008, 04:48 PM
Patrick's Avatar
Just water meth will get you close.
Legendary
Patrick is offline
post #4 of 66 Old 08-04-2008, 04:50 PM Thread Starter
jcmer22's Avatar
yea the egr delete is right around the corner im doing it in a few weeks and im trying to figure out how to have the dealer work in doing the head studs but i was just curious on how to get to or close to 500hp. im assuming im close to 430rwhp now. were do you recommend getting the injectors and turbo? turbo cant be that much cause i can sell mine to?
jcmer22 is offline
post #5 of 66 Old 08-04-2008, 04:51 PM Thread Starter
jcmer22's Avatar
is water meth something that you run all the time or is it like nitrous. im looking for the hp to always be there.
jcmer22 is offline
post #6 of 66 Old 08-04-2008, 04:53 PM
Marty's Avatar
You can run it all the time, but you have to refill it.
Personally I wouldn't run it for anything other then cooling application's.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #7 of 66 Old 08-04-2008, 04:57 PM
Patrick's Avatar
Its always there. I guess you could put it on a toggle switch if you wanted to. Its not ALWAYS there, but injectors and a turbo arent ALWAYS there either. The Meth kit will referance boost on the stage 2 kit and boost and EGT's on the stage 3 kit. It will start flowing water meth as those numbers climb. You could also do an Industrial Injection Hybrid turbo with your stock injectors and some good tuning...that will get you very close as well. If you add 190cc injectors to the Hybrid turbo you will be slightly over 500 probably closer to 515. Lots of options, and lots of ways to get you there.
Legendary
Patrick is offline
post #8 of 66 Old 08-04-2008, 04:58 PM
Patrick's Avatar
That would be just water then for cooling, and it will still add a little hp. If you go with water meth you will want to get some new tunes. This way they can cut back the timing a little bit.
Legendary
Patrick is offline
post #9 of 66 Old 08-04-2008, 05:08 PM
jamstoyz's Avatar
like maintain said, get a 03 turbo but there hard to find and a lil expensive. if you want, i can have the guy who built my truck punch out your stock injectors. it gives around 25 hp. i think he can go bigger but you would need a better fuel system.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #10 of 66 Old 08-04-2008, 05:23 PM Thread Starter
jcmer22's Avatar
what do you think your running for hp now?
jcmer22 is offline
