Can I Haul It??? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 08-03-2008, 03:13 PM Thread Starter
topdwg's Avatar
Can I Haul It???
Hey all I'm thinking about buying this toy hauler, but before I do I just wanted to get some opinons on if I can safely haul it? All inputs would be greatly appreciated...thanks My truck info is in my sig...
UVW: 10350
Dry Hitch Weight: 2020
Dry Axle Weight: 8330
NCC (Net Carrier Capacity): 4050
GVWR: 14400
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #2 of 23 Old 08-03-2008, 03:15 PM
00strker's Avatar
i would think so
2000 7.3 Few mods...SOLD
2003 Common Rail tow rig / DD
2006 Harley edition F-250.. 10in Fab, 24in Rockstars, 38x14 Kuhmos, 4in MBRP, Gearhead tunes...NO STUDS
00strker is offline
post #3 of 23 Old 08-03-2008, 03:36 PM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
I take that it is a tow behind and not a 5th wheel? You should be alright, make shure you get a weight distrobution hitch and a anti swaybar set up
Mike
"The Iron Pig"
mudrunninpig is offline
post #4 of 23 Old 08-03-2008, 03:41 PM
Big Tone's Avatar
Quoted: 2 Post(s)
I hope thats a fith wheel? bit heavy for a tag along.
Big Tone is offline
post #5 of 23 Old 08-03-2008, 03:44 PM
BLACK_PSTROKE's Avatar
if you dont have a set of overload springs you might want to invest in some.. other than that you shpuld be fine
09 F250 FX4
2n006 F-350 fx4 lariat
cc. 6 sp. man. SOLD..........
MEMBER $5.00 gallon club
NRA member
BLACK_PSTROKE is offline
post #6 of 23 Old 08-03-2008, 03:45 PM
CoalRollinRoosterCruiser's Avatar
Thats what i was thinking. Seems a bit heavy to not be a 5th wheell.
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #7 of 23 Old 08-03-2008, 03:51 PM
StarDriver's Avatar
Put airbags under the truck, it will level the truck out and ride better both loaded and empty.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #8 of 23 Old 08-03-2008, 03:58 PM
Turnin' JP8 into noise!
duck's Avatar
I can't imagine them making a tag along with a 14k gvw since the class V hitch is only rated at 12.5k (IIRC)...that said, should have no problems pulling a 5th wheel that size. (I second the previous recommendations for the helper springs or air bags, though.)
06 F350 Harley Edition
Crew Cab Long Box
Auto Meter Ultra-Lite Gauges
MBRP T304 SS 4" Turbo Back
AFE Stage II intake
Zoodad
Fluidampr
B&W Turnover Gooseneck Hitch
Xtang Revolution Tonneau Cover
Line-X w/ removable Carpet Bed Kit
2.5" Leveling Kit
BFG A/T KO 285/65/20R
Recon Smoked Cab and Tail Lights
If you ain't CAV, you ain't sh&#!!!
duck is offline
post #9 of 23 Old 08-03-2008, 06:27 PM
mrnecsteve's Avatar
You will need a hitch with a 2 and a half inch bar if your current hitch is factory. Your truck will be heavy in the back and light in the front by a LOT . An equaliser is needed ,airbag or not.
I have done 10,000 pounds on a low profile dump trailer with mine. If you hit a dip in the road while turning thru an intersection (normal road crown),it will startle the crap out of you (without an equaliser).
mrnecsteve is offline
post #10 of 23 Old 08-03-2008, 06:37 PM
PRWSTRK_Dan's Avatar
+1 For Airbags!
Daniel, 18
Graduated 6/18/2010: Wyotech in Laramie, Wyoming for Diesel Technology with studies in Advanced Diesel
Trucks:
Dad's truck:
2002 F-250 Lariat, CC, SB
7.3 Auto Usual Mods
My Truck:
1986 Ford F150 4x4 300, 4 on the Floor, Cobra 29 WX ST CB, Dual 4 foot whips bed mounted, rusted in normal places, more than normal rust
PRWSTRK_Dan is offline
