"How to blow my headgaskets" tips - Ford Powerstroke Diesel Forum
Old 07-31-2008, 11:28 AM
Hey Powerstrokers,
Never thought I'd ask this, but here goes the scenario:
I found a dealership I do business with, right up the street, that will take care of the headstud install under warranty with no questions asked. Problem is that I don't have blown headgaskets. I have the current mods in my sig and my truck has been running absolutely beautiful. Any advice on how to help me hurt my stock bolts without causing any other major damage? Thanks in advance!
Sergio
Old 07-31-2008, 11:34 AM
rdc rdc is offline
Grumpy Non-Socialist
Rest of post deleted ...
Old 07-31-2008, 11:36 AM
Send a message via AIM to blowinsmoke4life
put ur foot in the pedal and dont let off (this not recommended or backed by anyone or anything onp owerstroke.org or any of powerstroke.orgs affilates) anmd ggod luck weith that
Old 07-31-2008, 11:37 AM
I don't know nuttin....
Talk to DJ, he can write you a tune that will lift them heads right up....
Old 07-31-2008, 11:54 AM
Originally Posted by CHenry View Post
Talk to DJ, he can wrote you a tune that will lift them heads right up....
That's good thinkin' right there. I think I will give him a shout.
Originally Posted by rdc;
Something about starter fluid...
...Probably not the smartest of choices, but thanks for the input
Sergio
Old 07-31-2008, 01:22 PM
Illiana Chapter Director
Originally Posted by iLoveSoccrMoms15 View Post
Hey Powerstrokers,
Sergio
Hook up to something heavy and tow it on the looney file. Don't be easy and they will go.
Old 07-31-2008, 01:27 PM
Now give DJ a call and
Old 07-31-2008, 01:49 PM
say no to rolling coal
Whoa!!! Can't you just float the service manager or the tech a little something on the side to push it through under warranty? I'd check that route before I went tearing up my truck on purpose. If you do the studs proactively then you can be assured that your heads and deck are still in spec... Why risk cracking or warping the heads???
Old 07-31-2008, 01:50 PM
+1 here on that. 10K lbs and keep it punched going up a hill till they pop. Only problem is that Ford might send an inspector out or request pics of the pistons. If the pistons have star patterns on them and more than likely your warranty claim will be DENIED. The programmer will cause star marks on the pistons if you didn't know but I have seen unprogrammed trucks with the star pattern but they are heavy haulers.
Old 07-31-2008, 01:52 PM
Almostdunfukinwidit
talk to the tech about that
