Originally Posted by CHenry
Okay, the great state of Oklahoma has decided to buy me some goodies for my rig (I got a raise at work  ) soooo... Hers what i'm thinking.
Stax
Lift and leveling kit
wheels
Tires
Train Horns
I have checked with Raul on the stax already and decided i need 5" to go behind my toolbox/tank but i don't know anything about lifting a dually. Not a huge lift mind you, maybe 4". And the wheels and tires - what size can i get away with and how do you handle the rear dualls?
I have a 5er camper so i dont want to render my rig useless for towing it.
Anyone with a lifted dually please chime in here.
To be honest Clay I won't do anything more than a leveling kit, but no higher than a 4", simply because I wouldn't go any bigger than a 35" tire or a 22.5 from American Force. With a 4" lift you should be fine, but then it all depends on what size tire you go with....because remember you not going to lift just 4", but another 3" to 4" depending on tire. So personally I would go with the same set-up I have, leveling kit and 35"s doesn't affect towing one bit and make all the difference with looks
As far as tire all depends on what wheels you want. The widest that most wheel maker make are 6" to 7" wide.....so my KMC Rockstar wheels which are 17x7 make the sidewalls on my 35" BFG A/Ts bulge bad, almost making the center of my tread higher than the sides.....just something to keep in mind. I was going to go with American Force 22.5, but not for 8k......more power you to if you can afford that.
Now for the rear tires, I got a line on a guy who can get the correct 2" wheel spacers that your going to need for a great price. Even if you don't go with the guy I know, keep in mind that it needs to be 2" because you'll be cutting down your stock studs if you go any smaller and it needs to be hub centric, just trust me on that on, I learn that the hard way
Oh yeah don't worry about the tires sticking out from the fenders, its not that bad, maybe an inch at the most
