2 cycle oil and EGR do they mix? - Ford Powerstroke Diesel Forum
Old 07-28-2008, 03:44 PM
Many are running about an once/per gallon of diesel of 2 cycle oil in their rigs for lubrication, will this cause the EGR valve to coke up quicker in the 6.0's or does it not effect the EGR valve?
Old 07-29-2008, 03:50 AM
Since the TCW-3 is ashless I would guess there isn't an increase in soot or carbon. I have the EGR "non-operational" with my SCT so I can't say for sure.
Old 07-29-2008, 06:53 PM
Thanks, it sure runs smoother and quiter with the 2 cycle in the tank
Old 07-30-2008, 03:56 AM
Sure does....
Old 07-30-2008, 05:33 PM
I unplugged my EGR and gutted my cat......been running it for about 8000 miles, no problems, been getting 17-18.5 mpg....... after reading that unplugging the EGR makes the turbo spool less I hooked it back up and yes, the turbo spools up about 5-7psi more, runs a little better. I want to run it with EGR plugged up to see if it does anything to mileage.......2004 model 6.0
Old 07-31-2008, 04:25 AM
Are you running oil with your fuel or just doing an eval on how it runs with the EGR hooked back up?
Old 07-31-2008, 01:04 PM
both, I alternate between 2 cycle and Diesel kleen every time I fill up, want to see whast happens to mileage over the next 5000-6000 miles
Old 08-01-2008, 07:00 PM
STAKK, did u hut the cat or remove it with a cat delete, if gutted how did u go about doing it
Old 08-03-2008, 04:08 PM
Removed the cat, used a 5psi hammer and steel bar and went to work, inside looks like a cros between screen door and steel wool......... beat everything out put back on
Old 08-21-2008, 01:13 PM
Fuel mileage dropped to around 16 mpg with the EGR plugged back up......unplugged and filled up two tanks worth, mileage back up to 18.3mpg
