Air Intake Upgrade Suggestions - Ford Powerstroke Diesel Forum
Old 07-28-2008, 04:44 AM
I recently bought an 04 F250 6.0L 2WD. This past weekend I put on an MBRP turbo back 4" exhaust(No Cat). My next planned upgrade is the air intake. I have been searching through threads and such and see many different models, makes etc.. I'm not building a monster (yet). I'm looking for increased flow etc. and it doesn't have to be overkill. Just a good upgrade. And $$$ is always a factor. Any suggestion will help.
After I do the intake, I am planning on some gauges (EGT, Boost) and then perhaps a performance programmer or chip.
Old 07-28-2008, 04:47 AM
Ole White
WELCOME TO ORG! ! !
Checkout AFE, Airaid, or S&B all three have nice setups
One of the Vendors here on the ORG should be able to help you out
Old 07-28-2008, 04:48 AM
I use Airraid. Just avoid K&N and you should be fine.
Old 07-28-2008, 04:50 AM
Raging Lunatic
For price and washability, I have an Airaid. However a lot of people use the S&B and many others. You will get responses to keep your stock filter and that is fine and it will flow very good; but I changed mine due to the cost of filter replacement, not flow.
Old 07-28-2008, 04:56 AM
Should I just get a drop in replacement or the whole kit which includes the new air box? Ive also seen posts where guys cut a hole in the front shroud to increase flow to the air box. Any experience with that?
Old 07-28-2008, 04:59 AM
Raging Lunatic
For ease of maintainance I would use the whole kit. And the Zoodad mod will increase cold air intake and sound, I did it to mine as well.
Old 07-28-2008, 05:42 AM
Thanks for the suggestions. I ordered the AFE Stage II, and will do the zoodad at the same time I install the AFE intake. FYI, I got it from Thoroughbread diesel. It was significantly less expensive than most sellers.
Thanks again. I may not post alot, but I do read alot. There is a lot of good info here.
Old 07-29-2008, 04:52 PM
I did the zoodad and bought an aftermarket oem replacement.. Think Im gonna buy the whole set up later just due to the fact that I thought it was a pain in the arse to take out and put the cartridge back in..
Old 07-29-2008, 05:01 PM
Send a message via Yahoo to 06ARMADILLO
Ok, not to hijack (again) but what is the Zoodad? I have Googled the crap outta it, and just a lotta Powerstrokes rollin coal. So, help out and educate me here.
Old 07-29-2008, 05:02 PM
welcome to the site
check out AFE
