Removing front brake rotors. - Ford Powerstroke Diesel Forum
Old 07-24-2008, 02:54 PM
How do I remove the front brake rotors on my 03' F350? Do I have to remove the whole hub or can just the rotor be removed? If anyone has pictures or a diagram they could share that would be great.
Arch
Old 07-24-2008, 02:57 PM
duct tape & zip ties
Arch
What you need to do is, jack up the truck put it on jack stands. Remove the tire, then remove the caliper and caliper mount. Then the rotor will slide off the lugs.
Old 07-24-2008, 03:01 PM
I know the steps but when I get to the rotor, it does not slide off and I can't see any set-up for a puller and I have put a bar to it but it does not budge.
Arch
Old 07-24-2008, 03:04 PM
give it a couple smacks it will come off ......i do my brakes all the time and its just like mentioned above tires calipers and slide off disk
Old 07-24-2008, 03:09 PM
I've smacked the hell out of them and not budging. I guess I'll have to come up with some way of pulling them off. At this point I could not even tell if they would come off with out removing the hubs.
Arch
Old 07-24-2008, 03:11 PM
Is this a 2wd truck.
Old 07-24-2008, 03:12 PM
get a bigger hammer..........but on a serious note you really dont need to take the hubs off ....have you tried spraying with wd-40?
It is a 4X4 03' F350 SRW.
Arch
Old 07-24-2008, 03:17 PM
Havn't put any WD-40 on them but I'll give it a squirt when I try to remove them this Sat.
Arch
Old 07-24-2008, 07:35 PM
Send a message via AIM to blizzardwarrior7
Yea, shouldnt be THAT hard, lube (WD-40) them up .
