Air Pressure in Tires When Towing
I have Michelins on my truck and I tow a 5th wheel (10K+) from time to time. They'll go up to 80 psi and I usually run with 75 psi all the way around when I AM towing but now I'm rethinking that. Should I go right up to 80 psi and have something a bit less in the fronts - say like 60 psi or so?
Safest thing to do would be to set your tires to max PSI when cold. So if your sidewall says 80psi max.... then set them to 80 psi cold.
I always run less in my front than my rear. Think about it, the rear supports all the weight when towing. I usually run 70 in the rear and 55 in the front towing. Not towing I run 55 all around. All tires and trucks are different though, just play with it.
safest thing would be to set it to manuf tire pressure. Usually thats about 80% of the max on the sidewall.
I run 60psi all around all the time. Gives me the best ride and best tire wear. I never have had a problem with it even when towing heavy loads.
with u pulling a 5th it would be a good idea to have your tires right on... they will wear correctly as long as u check them every couple of weeks and u rotate them when u should. i bought a digital tire pressure gauge, its worth it to keep your tires in check
and it sounds like u have load range E tires with them going up to 80 psi so u have good tires for ur rig. perfect for towing like u do.
