Hi,
I brought my truck into the dealership to fix an oil leak between my bellhousing and engine. They said they couldn't identify where the leak was coming from so they added a dye to the oil, told me to drive it for a week then bring it back - but my question is, they also said they recalibrated my PCM to the latest (whatever).. ever since that day my EGR temps have been about 100º hotter. I notice when I'm idling about to shut off the truck it usually warms down to 400 quick, but now it's at 500 and takes forever to cool off. Any idea why it would run hotter, and what's the purpose of recalibrating my PCM? TIA |
The PCM (Powertrain Control Module) is basically a computer, that monitors all of the sensors in the truck and make adjustments accordingly.
Im not sure why it would be that hot, I had mine re-flashed a few months ago and I didnt notice much of a difference in EGT's but I could have a different flash that you do
EGR or EGT temps?
I'm pretty sure that Ford pays the dealership to do those updates. So even if you didn't need it...you got it, and the dealership got paid a few bucks. Why it would run hotter I have no idea.
I'm sorry EGT temps. Yeah I dunno... they charged me $100 surcharge though.. all they did was put the dye in. ugh!
Make sure you dont pay the 100 bucks again the next time your in for the same problem.
At the bell housing-block it could be the rear main seal leaking but it could be leaking up above and just showing up there.
I had my 07 reflashed a few wks ago at my dealer. I took it there purposely to get the flash update. It was under warranty, not $1 it cost me. They also replaced my Fog light assembly for free too b/c it wouldn't adjust. Try a different dealer maybe??? $100 sounds like a used car warranty deductable, not a new car warranty.
mines been leaking like that for a long time. i see no real fix to that problem other than really digging in there. im cool with a drip every now and then. and yeah the reflash shouldnt really change your egt temps. I would look into that some more
