Man this is driving me crazy! How much oil does my truck hold? I'm trying to do an oil change, but I can't find out how much to put in? I'm thinking it's 15 quarts? Sound right???
I'll use this truck last week as an example. Guy ran his truck 17,000 miles on an oil change. The oil areated so bad it started using it. Truck came in as a not start, I checked the dip stick and it wasnt on the dipstick. I put 12 qts in it and it fired right up. Thats why we have a dipstick.:thumb:
You knew I would respond.
Why didn't you just drain the rest and put in 15 quarts? Surely he needed a new filter too. That would have made better sense.
It goes like this, 3 qts low will not show on the dipstick. For all I know it was only 4 qts low. So after I got to 6 I said, well hell! I got to 12 and went ahead and swapped out the filter and topped it off. I would have never guessed it was that low. :dunno:
I really don't think that anyone could possibly believe an engine that holds 18 quarts will burn up when it is 1 quart low (or even two). One quart +/- is really of no consequence on ensuring proper concentrations of oil additive packages or on dilution of the wear metals that stay with the "dirty" oil. I know my UOA after 5000 miles still shows good, but I change it anyway due to viscosity shearing in the HPOP system.
As one person posting stated - keep it between min and max: 13-15 quarts (or for matter of continued debate 12-14 quarts). Ford specifically states all the way down to 13 is quite fine. SO, adding 14 quarts is also quite fine. For conservatism, just keep it between midway and full.
The only reason for the discussion is that overfilling is a documented problem. Trying to estimate a spot on the dipstick above the max to match 15 quarts is really of no value according to Ford (again they advocate anything between min and max is fine).
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
