Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 06-22-2008, 02:35 PM
1tonstroker 1tonstroker is offline
Exclamation 06 Stock Fog Light Install?
I have an 06 F350 that didn't come with Fog Lights. I bought some fog lights and I was wondering if it had the wiring from the bumper to the dash? I could buy a headlight switch w/ fog light controls and use the stock harness. So, does it have the stock harness? Or will I have to run wire? Thanks fella's!
Old 06-24-2008, 01:47 PM
matt_05stroker matt_05stroker is offline
I have a 2005 F250 and I just installed factory fog lights,unfortunately you have to run wire,mine didn't have any harness.I just wired them to switch. Auto Zone has the pigtails you'll need for the light bulbs.The same plug as the 9006 bulb uses. Tis way you can use the fogs with the high beams.
Old 06-28-2008, 08:53 PM
Autozone didn't have those pigtails... What do I do?
Old 06-30-2008, 03:34 PM
You can try a salvage yard,( I was wrong, it's the pigtail for the 9005 bulb), This is the number of the high beam bulb in a vehicle with a four headlight system. My 99 Silverado had these bulbs, for example. You can cut the plug (pigtail) from any of these vehicles with a four headlight system. I hope this helps you out.
Old 07-04-2008, 04:34 PM
BUMP BUMP Can I use the 12 volt power from my parking lights since I want my fog lights to come on when they do? Thanks!
Old 07-04-2008, 04:53 PM
redracer62 redracer62 is offline
i found it on ebay one time, it was a factory fog light install kit. it came with the factory switch harness any everything. its was like 250$ tho.
Old 07-04-2008, 05:18 PM
Yea, you can use the parking light power, but you may want to use a relay so the fog lights wont overload the circut.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
