Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #11 (permalink)
Old 06-09-2008, 06:43 PM
redracer62 redracer62 is offline
Originally Posted by Lethal03PS View Post
Thanks...Ill give that a try. That was the first time I had ever been at the track too.
I forgot to mention that I ran with the tow/haul button on, is that ok or a bad move.
i dont think it really makes a diff. did you switch from the street tune to the race tune while at the track? if so the truck prolly didnt fully learn the tune yet, usually it takes my truck like 60 miles to learn
  #12 (permalink)
Old 06-09-2008, 07:08 PM
Lethal03PS Lethal03PS is offline
Then thats probably what the problem was. I should have just left the one tune on there, instead of switching at the track. I thought it was just the tranny that needed a couple minutes to relearn.
  #13 (permalink)
Old 06-09-2008, 07:43 PM
william_04_x william_04_x is offline
load the race tune and drive for a couple of days...alot of guys use Xtreme Race for a daily driver tune...it will feel weird with the convertor locking in all but first gear...at least load it and drive to the track(if it's more than a few miles from home)...leave tow/haul off....the bugs got you now!!
  #14 (permalink)
Old 06-10-2008, 04:53 PM
its mostly the tranny that has to relearn. thats what i do is load it up a couple days before the track to make sure its learned. i kinda drive it hard those 2 days cause if you drive it easy, it will learn how you drive, then you go to the track an drive like a mad man an it is like wtf. it will still run good but you wont get the most
  #15 (permalink)
Old 06-10-2008, 05:18 PM
thanks, ill keep you guys updated when the next track day is.
  #16 (permalink)
Old 06-28-2008, 12:17 PM
07Harley 07Harley is offline
I am running the insanity tunes from Tadd at Elite Diesel on my 07 Harley and in the 1/8 mile i am running 8.9 and in the 1/4 14.1
  #17 (permalink)
Old 06-28-2008, 12:42 PM
Yeah, Im going to gove it another try b/c I found a big boost leak about a week ago. About 2 mos ago I cleaned my egr valve and must not have screwed it back on tight enough. I went to check it and the bolts were really loose and there was an oil redidue all over the manifold from where it was leaking. When I was racing I was only pushing 15psi. Fixed the leak and the power difference is amazing. It pushes 30psi easy now. Im sure it will bring my times waaaay down.
  #18 (permalink)
Old 06-28-2008, 01:13 PM
sjreno sjreno is offline
Awesome job!
  #19 (permalink)
Old 06-28-2008, 03:12 PM
Harohunter Harohunter is offline
PREEEEMIUM!!!!!!!!!!!!!!!
Im running 8.7 consistently with 31's I am launching at 2000 RPMs EXACTLY if i go like 100 more RPMS it will roll through the brakes. By the way the RT is NOT calulated in your ET so no matter how late you leave your ET will still be the time.
Also i changed from street to race to street while at the track and the race tunes was about.1 faster and both streets ran 8.87
4x4 Launch with a CC SB
  #20 (permalink)
Old 06-28-2008, 09:42 PM
StrokerAce06 StrokerAce06 is offline
Exclamation
I didnt run any of dj's tunes, just innovatives for now. Next time im prob. going to run dj's and see if my times differ. Im not exactly sure of the hp numbers. I turned over better times with the extreme street than the extreme race....That one I didnt see coming.
I run 9.4's with a 1.02 reaction time. I run dj's looney tune
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
