Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 10-23-2006, 04:37 AM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
Which Kind of Headlamp?
How do I know if I have a sealed beam or regular Headlamp other than taking it apart. I don't think it says it on the window sticker, and it doesnt say in the manual. Is there any way to find out.
Any help is appreciated.
Thanks.
-BG06.
Old 10-23-2006, 04:47 AM
F350SUPERDUTY F350SUPERDUTY is offline
Send a message via MSN to F350SUPERDUTY
Shed a little light on the subject.
Thanks.
-BG06.
Idk of too many vehicles with a sealed beam anymore, other than farm equipment. Yours should be the type that the bulb & connector pull out the back. Usually have to twist oneway and carefully remove it.
Old 10-23-2006, 04:52 AM
The only reason I say that is because the owners manual has two sets of instructions for changing bulbs, one is aerodynamic, the other is sealed beam.
-BG06.
Old 10-23-2006, 07:44 AM
bigwes bigwes is offline
Send a message via AIM to bigwes Send a message via Yahoo to bigwes
sealed beam healights usually only come on the work truck type f250's....it will have plastic all around the glass square headlight with grooves for screws down each side, they set further back in the houseing.....same thing as jeep headlights........most f250s will have composite headlights with h13/9008 bulbs....these stick out flush with the front end and you can see the bulb easily inside...hope that helps..
Old 10-23-2006, 07:50 AM
Well I know I have the H13 bulbs, if the sealed beam has a different bulb then I know for sure that I don't have those.
-BG06.
Old 10-23-2006, 09:55 AM
-BG06.
just noticed the pics of you truck and yes, you have the composite headlamps
Old 10-23-2006, 01:50 PM
Ford 1 Ford 1 is offline
Send a message via MSN to Ford 1 Send a message via Yahoo to Ford 1
sealed beam are the old bulb style. With the retaining ring and the adjustment screws.
