Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #11 (permalink)
Old 05-14-2008, 08:53 PM
TurboSevenThree TurboSevenThree is offline
Originally Posted by tonypagnano View Post
not to jack this thread but speaking of rpms, my 99 7.3 runs 50mph at 1500rpms in overdrive and runs at about 2100rpms at about 70mph. I believe i have 3.73 this sound right? (single cab single rear wheel f350)
well I have a 2000 7.3 and at 70 the rpms are at around 2300 with 4:10 gears so i think that's about right. IF we are both talking factory wheel/tire size, I am.
  #12 (permalink)
Old 05-14-2008, 09:16 PM
Hamiltonbuilt Hamiltonbuilt is offline
I get
12 to 12.5 towing 7000lbs trailer daily around town
About 10 towing 10,000lbs boat. 65 to 75 mph
15 empty around town
15 empty 75mph trip
17.5 empty 65mph trip
Train horns should be here on the 15th.
  #13 (permalink)
Old 05-16-2008, 02:11 AM
jacksd3 jacksd3 is offline
I get 18-19mpg empty and about 14mpg towing 7k lbs at 65mph.
  #14 (permalink)
Old 05-16-2008, 04:25 AM
CLIPPERS CLIPPERS is offline
The mileage seems to be normal to me. I don't know why but I never checked my mileage while towing until I bought a Diesel? I was always told that anytime you tow or haul anything with some weight to it you should just push your tow/haul button and keep it in overdrive. I have learned that while pulling my 8000 lb camper that my truck will not shift into overdrive unless I back way out of the throttle. In overdrive it will run at about 1800 rpm under load. If I don't let it shift into overdrive the rpm's stay around 2500-2600 rpm's.
  #15 (permalink)
Old 05-17-2008, 05:21 PM
StarDriver StarDriver is offline
Slow down to 60-65 and your mpg will go up. I get 10 pulling a trailer.
Also, to all pulling a trailer, NEVER put your cruise on while pulling a trailer.
  #16 (permalink)
Old 05-17-2008, 06:16 PM
BryanH BryanH is offline
LSP Officer
Originally Posted by wustydemo View Post
bump...looking for more advice on using transmission when towing...any towing advice would be appreciated...
Pop in the tow/haul button and go to town. That is all the advise needed.
  #17 (permalink)
Old 05-17-2008, 06:26 PM
LSP Officer
Also, If you feel like spending a little coin, Get a 4" exhaust system. I recommend MBRP Turbo back. It will prolong the life of your turbo, By keeping the EGT's down.
There are plenty of thing's to do to enhance your towing experience. But if your load is only around 6K. There is nothing that I feel is a must besides the basics.
Oil/filter changes
Fuel Filters
Clean air filter
Tranny flushes
By the way. Did you say this is your first diesel. If not sorry for the unneeded info.
What kind of trailer do you have?
  #18 (permalink)
Old 05-18-2008, 09:48 AM
Shire Shire is online now
I find the cruise control tries to accelerate at inappropriate times going around curves and up hills. Any other reasons to avoid it while towing?
  #19 (permalink)
Old 05-18-2008, 10:00 AM
somebodyelse5 somebodyelse5 is offline
If something happens.....that 2 seconds you take to react is all it takes for you to melt your motor down. Need to be in total control 100% of the time and watching all of your numbers.
  #20 (permalink)
Old 05-19-2008, 04:08 PM
wustydemo wustydemo is offline
Oil/filter changes
Fuel Filters
Clean air filter
Tranny flushes
Yes this is my first diesel. The trailer is a 24' travel trailer...nothing fancy or heavy. Being my first diesel I am always wanting info and trying to learn all I can about it. So far I love the diesel motor!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
