Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 10-16-2006, 02:04 PM
BluegrassHaul BluegrassHaul is offline
2005 6.0L difference between Model A325 and Model A325C
Just trying to find out what the difference is in these 2 motors or are they interchangeable. Didn't know if the PCM would work for either.
Old 10-16-2006, 02:21 PM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
Hmm... I have heard something about this in the past, however I can't recall enough of the info in order to assist with your question. I think it had something to do with its build location BUT I'm probably wrong.
Marc will probably be able to help you.
Old 10-17-2006, 09:15 PM
Thanks for the reply. Thought this was the best place to ask this.
Old 10-17-2006, 09:23 PM
mschn99 mschn99 is offline
Banished
Im not sure about the "numbered builds", but if your referring to the early and late build motors....NO, they are not interchangable. They are slightly different in design and some sensor locatins and electrical connections are also different
Old 10-17-2006, 09:26 PM
This is the tag on the passenger side valve cover one is blue with Model A325
and one is red with Model A325C on it.
Old 10-17-2006, 09:39 PM
Banished
if they are both 05 motors, there were some very slight productions changes but nothing i see as making the motors uncompatable
Old 10-17-2006, 09:43 PM
They are both 05's. One guy told me the C was for Canadian and they had different emissions and may take a different PCM. Didn't know for sure so thought I would ask here.
Old 10-17-2006, 09:48 PM
Banished
im unaware if that is true.
Old 10-17-2006, 09:50 PM
OK thanks for your help Marc. Guess I'll let you know if it works when I swap it
Old 10-18-2006, 02:24 PM
I got the new motor today and the tag says its a California emissions compliant motor will this make a difference with the PCM?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
