2007 FORD F250 TRANSMISSION COOLER LINES CANT INSTALL! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-08-2013, 02:26 PM Thread Starter
2007 F250 6.0 power stroke.
I cant install the transmission cooler lines.. Its just flopping around in the radiator and i cant get it straight enough to bolt up to it!
Any help?
Cablekid is offline
post #2 of 3 Old 08-08-2013, 02:47 PM
So you unbolted the lines instead of using the quick connect couplings? If so you need to stick something in the lower radiator hose port and hold it steady while you thread the nuts. Hopefully the gaskets are still on the cooler studs/threads.
2005 F-250
FX-4 Manual Trans
MBRP duals
Coolant Filter
CCV Mod
Leveled, American Racing Mojaves Nitto Terra Grapplers
Looney
Livewire
Scangauge II
reilly828282 is offline
post #3 of 3 Old 08-10-2013, 02:55 PM Thread Starter
I got it at last! Lol
Cablekid is offline
