Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #31 (permalink)
Old 02-25-2007, 09:39 AM
05boosted250 05boosted250 is offline
Send a message via AIM to 05boosted250 Send a message via MSN to 05boosted250 Send a message via Yahoo to 05boosted250
Are the numbers you posted for the sticky, to the wheels or from the flywheel? And if its from the flywheel, anyone got stock numbers to the wheel? Curious to know what Im running with the Diablo set at 100hp tune. Thx
  #32 (permalink)
Old 02-25-2007, 12:04 PM
BFD99 BFD99 is offline
Send a message via AIM to BFD99 Send a message via MSN to BFD99
everything the manufacturers post are to the flywheel.
  #33 (permalink)
Old 03-11-2007, 07:48 PM
RamAirfreak98ss RamAirfreak98ss is offline
so what do any of the 04-07 stock 6.0s with the torqueshift run stock? like my extended cab 4x4 or a crew cab? I thought they were faster than "16.8s"? I guess it just feels faster than it is
My v6 grand am GT i know is about 16.0s so i should have my g/f drive the truck from a stop and ill see which one is faster
  #34 (permalink)
Old 03-13-2007, 10:22 AM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
on the first page of this thread i posted times i got with my stock '05 supercab longbed 4x4 truck with about 4K on the odometer. i've had the EBPS replaced and PCM reflashed (as per a recall) so i don't know what it'll do now.
The runs i did were on an empty road, using 4x4 High to get launched the 16.6 sec run was with a slight tail wind, the others were in the opposite direction/with a head wind. i imagine all stock trucks will run about the same. I'm curious to know what the modded trucks like Rodslinger's truck is doing.
  #35 (permalink)
Old 08-23-2007, 07:10 AM
jacksd3 jacksd3 is offline
Slight difference on the hp/tq numbers. The Ford sticker on my valve cover says 325hp and 560ftlbs torque. Slight difference on the torque value. My PSD is a 03 made in May.
  #36 (permalink)
Old 08-24-2007, 01:47 PM
Military Member
and that's right, in '03 the engine was brand new so Ford put a slightly conservative number in there for torque, just be sure no engine would make them a liar. as the years passed they got more confident and so advertised a slight increase. that have been some very subtle improvements to the engine too of course. If your engine is healty i'd wager that you could strap it to a dyno and actually find a little more power then what's on the sticker. ford is famous for conservative power ratings.
  #37 (permalink)
Old 08-25-2007, 02:38 AM
Hi jwiger, thanks for the clarification.
  #38 (permalink)
Old 09-20-2007, 08:24 PM
powersmoke4x4 powersmoke4x4 is offline
alright i need some advice i just put the edge juice with attitude on my 04 6.0 and i need some tips on how to get more power and smoke cause i see some trucks smokin like a coal factory and keep smokin as the slam the throttle but on level 5 when i stomp down i shoot a fat cloud and thas pretty much it and i need some help on what to set it all at
  #39 (permalink)
Old 09-20-2007, 08:42 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Your Edge likely will not roll coal like you're seeing other trucks do. Truthfully it is overfueling and contributes to high EGT's which can damage your engine if not kept in check. A properly tuned truck (tuned beyond stock) should burn off most if not all of the fuel once the turbo is lit. Big smoke doesn't always mean a truck is fast, either.
  #40 (permalink)
Old 09-26-2007, 06:09 PM
caissiel caissiel is offline
Torque is the same for any size of tire, but the force to move the truck ahead in a drag is much higher with smaller tire, torque is force x distance from axe of rotation
