Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 05-05-2008, 08:42 AM
alk8778 alk8778 is offline
Send a message via AIM to alk8778
03 vs 06 Turbo
I have a 2003 F250.. which came with the legendary 03 turbo. Just before the warrenty was up the dealership replaced the turbo, saying the vanes were pitting, but they replaced it with a newer 06 turbo. I want to go back to an 03 and found one at a junkyard for 20$ but it does not have the housing on the exhaust side... Is the housing the same between the two turbos to where i can swap the two, or should I pass up this opportunity?
Old 05-05-2008, 08:56 AM
saca93 saca93 is offline
WHAT IS THE DIFF FROM AN 03 AND A 06 BECAUSE IVE HAD MY TURBO REPLACED 5TIMES FOR NO LOSS OF POWER AND THEN I GOT 3 DEFECTIVE ONES . THE TRUCK JUST TURNED 64,000. BUT I LOVE MY TRUCK I WOULDNT GET RID OF IT FOR NOTHING!
Old 05-05-2008, 10:31 AM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
I don't think it's possible for them to put an 06 style turbo on an 03. I don't think the 06 pedestal will even fit. I'm sure you still have an 03 turbo. Did the whistle go away?
Old 05-05-2008, 11:33 AM
The level of the whistle decreased dramatically when they changed the turbo. I can remove the downpipe and count the fins, 10 on an 03, correct?
Old 05-05-2008, 11:43 AM
yesssir. As far as the 03 turbo you found, I would wait it out and buy one that is in dececnt shape. I've seen some at local junkyards and I don't know if I would even put it in the bed of my truck let alone anywhere near the engine compartment. lol
Old 05-05-2008, 08:29 PM
jayjma20 jayjma20 is offline
does anyone know if the 03 10 vane will fit on the 05s or 06s
Old 05-05-2008, 08:54 PM
TxPSD9673 TxPSD9673 is offline
yes you can do it i think one of the MAP guys did it on his 06' 06TWO50Diesel (Nate) did it i would talk to him
Old 05-05-2008, 09:01 PM
Maintain Maintain is offline
<-- 13.0 @ 102 launch
Send a message via AIM to Maintain
Pass it up...
see below and watch this video...
07 to 03 Turbo Swap
10 = 03
12 = 04
15 = 05
Originally Posted by TxPSD9673 View Post
yes you can do it i think one of the MAP guys did it on his 06' i forget who
Yeah, that was Eric. We put an 03 turbo and pedistal on his 07.
Old 05-07-2008, 04:40 AM
SuperDuty73 SuperDuty73 is offline
What is so much better with the 03 turbo rather than all the other years? The difference in the turbo fins really make it better? Can someone explain why its better?
Thanks I'm helping a friend out with his 6.0 I dont know them that well.
Old 05-07-2008, 05:06 AM
DKR DKR is offline
<--Pro Cooler Racer
I did (actually Marty did, I handed him tools) an 03 swap on my 07. What Marty listed is correct.
The only difference in mounting is the pedestal. So, if the dealer put an 06 on, they only have to swap pedestals too.
As for performance, I noticed a smoother quicker spool up, 4-5lbs more boost on same tunes and have heard reports of lower EGTs slightly. The 03s also move slightly more air at the higher RPMs. Think of an 03 as one small step down from a hybrid, but an improvement over the 05-07 ones.
And you get the cool whistle!
As for the one in the junkyard, I'd hold off. For $20, honestly I doubt it would be safe to use. Just my
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
