Stipped bolt help!!! - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 22 Old 08-03-2013, 08:28 PM
Quoted: 727 Post(s)
Do u have access to a TIG welder?
Corey@CNCFAB is online now
post #12 of 22 Old 08-03-2013, 09:19 PM Thread Starter
xtremexj's Avatar
Nope, just a MIG. It would be a no brainer if I had a TIG.
2003 F350 SC,SB, 4x4, 6.0L, 5R110, SCT Xcal3 by Innovative and Quick Tricks, zoodad, 05 Accufab elbow, 4" Magnaflow turbo back, 4" ProComp lift, LT315/70R17, custom bumpers
Best time to date: 13.75 @ 96.42MPH
xtremexj is offline
post #13 of 22 Old 08-03-2013, 09:23 PM
Try heating it with a blow torch, or mig weld something onto it. The heat alone will expand and contract the metal, should work loose after that.
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #14 of 22 Old 08-03-2013, 09:51 PM
GET MY ENEMA BUCKET BRO!!
jacksun's Avatar
Quoted: 145 Post(s)
What about jbweld maybe I say that work a few times. Also make sure to soak it in pblaster
coolant-filter-EGR delete-blue spring-ARP's-BPD oil cooler-5in exhaust-horn blasters shocker kit-SCT running SRL++-beans tank sump-BPD water pump-and 4x4 complete
DEUS VULT
jacksun is offline
post #15 of 22 Old 08-04-2013, 06:57 PM
Jay06f250's Avatar
Quoted: 4 Post(s)
Do you have a picture? Does the bolt head stick out at all, like a button head? If the head sticks out, like a hex head from what its tightened into, you could cut a slot into it. Then use a slotted bit on you ratchet or coordless impact to remove it. If its flush, well I guess you would need to weld something to it. I have used easy outs before , but the snap on ones have always gotten out what I needed em to.
2006 F250 CCSB 4x4 6.0, Scanguage II, IPR coolant filter, Amsoil oil bypass, Max Tow gauges, Blue spring, Gearhead tunes
Jay06f250 is offline
post #16 of 22 Old 08-04-2013, 08:23 PM Thread Starter
xtremexj's Avatar
The head is still there but it is in a difficult spot to get anything long into. I am going to leave it for another couple of days and see if another idea I have can be made to work.
I am still leary to try and cut into it for fear of getting metal shavings into the head. I know I can get most of it out with a magnet but with my luck something will get missed.
xtremexj is offline
post #17 of 22 Old 08-04-2013, 08:51 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
If the head is still there use a 7mm turbo socket!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #18 of 22 Old 08-05-2013, 04:49 PM Thread Starter
xtremexj's Avatar
Do you have a specific brand? If its the same as this it won't work:
5-pc BOLT-GRIP
This was the first set of extractors I bought and even the 8mm won't bite on the 8mm rounded head.
xtremexj is offline
post #19 of 22 Old 08-05-2013, 05:00 PM
theplumbingmedic's Avatar
Great link!!!
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #20 of 22 Old 08-06-2013, 10:37 AM Thread Starter
xtremexj's Avatar
So, as a last ditch effort before bringing out the zip disc, I am ordering a deep fluted extractor from Snap On. It will be here tomorrow so hopefully it's not a waste of another $25.
BEXD101, Extractor, Deep Well, 5/16"
I'm hoping that it will sit better on the head and be able to grip it and get the bloody thing out.
xtremexj is offline
