Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 10-13-2006, 01:24 PM
DaddyO DaddyO is offline
Any one notice this....
The other night I was driving home and accidently tapped the brake pedal while I was still holding the accelerator pedal at a constant cruising speed and the tranny kicked down a gear as if I were going to pass someone.
I have routinely been able to duplicate this scenario and would like to know if it is set up this way from the factory?
Old 10-13-2006, 01:43 PM
CHenry CHenry is offline
Sooner Powerstroker
Yep shes made to sense that load change on the engine and shift accordingling to hold the speed.
Old 10-13-2006, 07:48 PM
mschn99 mschn99 is offline
Banished
the torqueshif is also designed to use the trans to downshift to essentually "engine brake" like you can with a stick...
Old 10-14-2006, 01:58 PM
brdgraf brdgraf is offline
Yes sir, mine does the exact same thing. I think what its doing is unlocking the torque converter when you tap the brake like that. Had an 04 and it did that as well.
Old 10-14-2006, 02:59 PM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
it'll really freek you out the first time you are doing 60 in tow/haul mode and hold the brake pedal down. With the tow/haul enabled speed holding programing will actually down shift the tranny and cut fuel to the engine, all you'll hear is the engine spinning at speed, keep holding the brake down and when the engine speed gets to around 1K it will add the fuel back in, rev, down-shift, and cut fuel again all the way down to a crawl. give it a try on a long down hill run you don't even need a load on the truck to get it to do this.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
