Air filter Change - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-22-2008, 07:59 PM Thread Starter
tylerwitt34's Avatar
Air filter Change
Does anyone have a write up on changing the air filters on these 6.0. I just did one at work on a work truck and it was a total *****. Lol i'm a 7.3 guy as u can see in my sig....
10,000 Lakes ORG chapter member
03 7.3 F-350 Crew Cab FX4
Pro Comp Leveling Kit
4inch MBRP with Delete Pipe
AFE Stage 2
Turbonetics BB
Industrial Injection Stage 2 Split's
ATS Stage 1 Tranny
DP Tuner No Start 40 60 80 120 140(smoke) Lope
ITP Overboost Annihilator
Dipricol Guages Boost Tranny EGT
tylerwitt34 is offline
post #2 of 6 Old 04-22-2008, 08:35 PM
Quoted: 15 Post(s)
Use ONLY OEM filters (which are made by Donaldson).
No aftermarket unless you are heavily modded (over 500 hp).
"Change air filter when filter minder shows the need (in the manual).
I change mine more often, to be safe - most say it isn't necessary."
http://www.forddoctorsdts.com/articl...icle-06-01.php
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #3 of 6 Old 04-23-2008, 10:32 AM
Echo's Avatar
Haha, I agree they are a PITA to get out and put in.
Echo is offline
post #4 of 6 Old 04-24-2008, 04:45 PM
03f250stroke's Avatar
FDDTS - 6.0L Power Stroke Air Filter Removal
man Im gonna have to disagree with that statement 100%. You dont need to be heavily modded to install an intake. Ill tell you what to do, Go to the vendor page call around and get an AFE drop in replacement. The stock box will flow enough for a bolt on truck. Its around 60-70 bucks and simple but time consuming to install.
-Evan
6.HO
tuned by Eric
12.3
Originally Posted by shu873 View Post
Yeah, but your trucks a freak of nature...
03f250stroke is offline
post #5 of 6 Old 04-24-2008, 07:05 PM
Quoted: 15 Post(s)
What benefit are you looking for by spending the $$'s for an aftermarket intake? Studies have been done to show that you do not gain hp or mpg w/ an aftermarket intake (until you add other mods).
Here is one study worth looking at. Yes, this study was using an AC Delco filter, but the Ford Donaldson air filter is even better than the AC Delco. The comparison holds true. I have also read articles on measured hp that show no real world gains. I have yet to see anyone w/ a stock truck post statistically valid numbers showing a benefit from aftermarket air filters. There are much better mods to spend $$'s on than this (unless you like the looks of some RAM AIR style intakes OR the ease of filter change).
Powerstroke Mods and Maintenance
Some additional reading (hope the links are working):
K&N why so bad? - Ford Truck Enthusiasts Forums
Best Cold-Air Intake Brand for 6.0? - Page 2 - Ford Truck Enthusiasts Forums
Mark
post #6 of 6 Old 04-24-2008, 08:19 PM Thread Starter
This is a company truck i don't wanna mod this. Its a F-450 with a dump bed.
AFE Stage 2
Turbonetics BB
ATS Stage 1 Tranny
