6.0 making odd noise after shut off.
It sounds like a pump running. When i drive the truck and shut it off, it continues to run. if i cycle the key to on and then back off it stops. Truck is a 03, with an auto and about 200K on it. Any ideas? I can video tape the noise if need be.
What side is it coming from? Front or rear?
Is it a 6.4 or 6.0?
its not the truck in sig. i stated in the first post, its an 03. It has the 6liter. its a friends truck i borrowed while my 6.4 is in the shop, again.
the sound appears to come from the engine bay, but i'll check again after work |
I have a friend who has a 6.0 and his does it....its nothing he worries about....ford said it was fine too!
is it the injectors buzzing
EDIT: if so, it is just and old flash to help cool the injectors after shutdown |
why do they buzz after shutdown? |
Mind does that sometimes, its the vaccuum pump on the Pass. side fender well.
A friend of mine has an 06 and it did the same thing. He took it in for a bad injector and when they replaced it started doing that "buzzing" sound. He took it back and they reflashed the computer again and that fixed the noise.
If it is the injectors buzzing there is nothing wrong, just an older flash. Im still running the old flash too
