what tires can I fit - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-09-2008, 01:36 PM Thread Starter
glennpagano444's Avatar
Hi I was wondering what size tires I can fit on my 2006 stock with stock rims and no lift. Is 30.5 too big? How are these tires? Dick Cepek Radial Crushers
2006 6.0
F250 psd extcab 4x4 long bed
5" MBRP exhaust with cat delete.
X3 SCT with custom tunes by DJ
35" Pro Comp All terrain A/T
6" BDS lift Kit from Truck Toyz
glennpagano444 is offline
post #2 of 10 Old 04-09-2008, 01:40 PM
valetcruiser's Avatar
my 05 fx4 came stock with the equivelant of a 32" tire. not sure if yours sits lower than the fx4 though. i put bfg all terrains on it, stayed at an overall dia of 32" and never had problems.
valetcruiser is offline
post #3 of 10 Old 04-09-2008, 01:47 PM Thread Starter
So what are the largest tires I can fit then without cutting out any fenders or getting a lift
2006 6.0
post #4 of 10 Old 04-09-2008, 02:01 PM
I've been told 35's....but I have no proof other than people have said.
I put 36's on my 05,..but I did cut-outs
TANK'S 250 is offline
post #5 of 10 Old 04-09-2008, 02:03 PM
i couldn't tell you. i don't think i would go much bigger than a 33.
post #6 of 10 Old 04-10-2008, 04:47 AM
EODguyJake's Avatar
Quoted: 7 Post(s)
I'm runnin 305/70s on 16x8s with a 2.5in leveling kit and I had to trim about 2 inches off the corners of that lower front bumper plastic thingy. Any wider or taller and I would be SOL.
2015 F-350 6.7L, CCSB, SRW, FX-4
2004 F-350 6.0L SRW XLT Sport, Ex cab, SB, FX4-Gone after 10 years as original owner
There are very few personal problems that can't be solved by the proper application of high explosives!
Initial Success or Total Failure-EOMFD!
EODguyJake is offline
post #7 of 10 Old 04-10-2008, 05:29 AM
kmuncc's Avatar
I am running 305 70/R16 no rubbing and no lift or other mods to it I would say you could go a size bigger but they would probably rub some
here is some pics
2008 F-250 4x4 CC NAV H&S Mini Maxx, 5" Down Pipe Back Exhaust, S&B Intake, EGR Delete and Intake Elbow, ARP Head Studs, 3" Lift,LED Smoke Cab Lights, LED Smoke Mirror Lenses
SOLD 2004 F-250 FX4 Lariat CC 4" Turbo Back Exhaust Cat Delete, SCT Tuned By Innovative Diesel!, Zoodad Mod, Cobalt Pyro Gauge in overhead pod, B&W Turnover Ball Hitch
SOLD 1997 F-250 4x4 off road 7.3 ECLB man
kmuncc is offline
post #8 of 10 Old 04-10-2008, 05:43 AM
LHMissions's Avatar
I have a '03 6.0 - no lift, no leveling, stock wheels running my 2nd set of Nitto Terra Grappler LT 305/70R16 E's. The 305 is basically a 33x12.50x16 tire. Fits very well.
LHMissions is offline
post #9 of 10 Old 04-10-2008, 06:08 AM
Justinlw's Avatar
Quoted: 46 Post(s)
Send a message via MSN to Justinlw
You can run a 305/70, some people run a 315/75 with no problems on stockers with no lift. When you start getting into aftermarkets with bigger back-spacing, that's when you start getting the rub. On stock wheels with a 315/75 you might be ok, since you have no leaf springs to rub.
I ran 305/70s on mine stock for a while, but when I went to a 16x10 wheel, I had to lift it to clear.
2010 F250 Lariat FX4 6.4l
Carli Backcountry 2.5", 11+ Leaf Springs, SCT 3015R/Tyrant Tuned, Edge Insight CTS,
FloPro DPF Pipe, RCD EGR Delete/Elbow, Sinister Coolant Filter, 11+ Console
Justinlw is offline
post #10 of 10 Old 04-10-2008, 06:54 AM
magnumpeei's Avatar
if you run a 285/70R17 (32.8" tall), you won't need to lift it and you'll never have to worry about rubbing.
magnumpeei is offline
