6.0L longevity? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-01-2008, 08:43 PM Thread Starter
6.0L longevity?
how is this motor in the long haul, will it last like other diesels? how many thousand miles can you put on this motor
jayjma20 is offline
post #2 of 12 Old 04-01-2008, 08:47 PM
I'de say if it's a hauler around 150K miles maybe 200K if your lucky. If its a daily driver about 300K miles. My cousins 03 has had 3 engines and it has 120K miles but its a hauler.
2005F250 is offline
post #3 of 12 Old 04-02-2008, 12:21 AM
Streak's Avatar
Send a message via AIM to Streak
With regular (and proper) maintenance, it ought to last a while.
If you start adding tuners and fiddling around with settings, that's another story
Streak is offline
post #4 of 12 Old 04-02-2008, 12:51 AM
DoubleDpsd's Avatar
If you have a money tree you can make it last for a bagillion miles.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #5 of 12 Old 04-02-2008, 12:55 AM
slammedSI's Avatar
mine is a 05 with almost 180K its been used HARD. and has had a load behind it 85% of the time. only thing replaced is an alternator. GREAT MOTORS!
-Bobby Crews- AKA Dr. Cookie Cutter!
2012 Ford F150 Ecoboost
-STOCK-
A 7.3 with an edge should never get into a race. Unless it's with a kid on a bicycle.. and the bike has a flat.
slammedSI is offline
post #6 of 12 Old 04-02-2008, 01:15 AM
DryHeatDude03's Avatar
I think the 6.0s get too much of a bad rap. I've had my problems with mine, like anything else thats mechanical with moving parts stuff can break. But I still think its a very good engine. stud the motor, do an egr blockoff and perform regular maint. and it should run you a good long time.
-Chris-
2003 F250 SC/LB 6.0L 4X4
DryHeatDude03 is offline
post #7 of 12 Old 04-02-2008, 04:49 AM
I agree 100%!!!!!!!
but would have to add another -
TAKE CARE OF YOUR FUEL SYSTEM.
  • I think gauges would be a great help for reliability. You definitely do not want to drive with low fuel pressure.
  • Change filters often, use the right filters (fuel and oil).
  • Use synthetic oil and don't try to go to extended OCI's.
  • I also think a good additive is a big help in reliability as well (ensure lubricity and cetane). I know many will say you get adequate from the pump, but I like the insurance.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 12 Old 04-02-2008, 08:25 PM
reliability
The engine was originally designed to run upwards around 500,000 miles by International as per Ford requirments. if you take very good care of it I have seen some run very near that. biggest thing is to keep your oil changed!!! the injection system uses high pressure oil to operated the injectors. so clean oil means less problems with sticking injectors. believe it or not these engines need to be worked hard, ie towing and highway driving. idling and stop light to stop light is very hard on them. keep your fuel filters changed is the second big thing. As far as real engine problems, very few. egr coolers are a weak point but it is usually caused by high exhaust temps. The injector issue was ford biggest problem and they have finally come up with a good fix, and it only requires a pcm reflash by the dealer. I can say that 90 plus percent of the injector problem I now see are repaired by this reflash. I do see an occasional head gasket here and there but the engines themselves are pretty much bomb proof.
fabford is offline
post #9 of 12 Old 04-02-2008, 08:36 PM Thread Starter
glad to hear this motors aren't all that bad, i think when i do get mine i will do head studs and egr block off anyways
jayjma20 is offline
post #10 of 12 Old 04-02-2008, 09:06 PM
csford's Avatar
one of my friends have 400,000 kms and all it was used for was oil field hauling
chris
:2003 f-350 4x4 6.0
4.5 donahoe racing lift 305/75r16 toyo M/T's
bully dog triple dog
AFE filter
strait piped
150 gal diesel/gas tidy tank
warn hubs
auto meter ultra lite 2 pryo
csford is offline
