How does the EGR valve get that dirty?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-30-2008, 03:42 PM Thread Starter
I pulled the EGR valve on my buddies truck today(42K miles). The thing was beyond clogged. We cleaned it up and reinstalled it. Truck runs great. My question is how does it get that bad? He's had no trouble at all. We pulled it more for maintenance then anything else. Just very surprising!
2005 Ford F-350 Lariat Crew Cab 4X4
6.0L Diesel
5 Speed Automatic
ackman70 is offline
post #2 of 6 Old 03-30-2008, 03:53 PM
Powerstroke W/smoke's Avatar
ford knows about this issue, they even recommend replacing it rather than cleaning it. it's just one of those "fantastic" new emission parts on our trucks lol
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #3 of 6 Old 03-30-2008, 07:33 PM
Quoted: 23 Post(s)
Extended idling is one of the quickest ways to cause all the soot formation and plug the EGR. Even short runs and not letting the engine get to full operating temperature will contribute.
I personally believe that fuel additives can help the burn efficiency and help prevent soot formation. Synthetic oils that withstand high temperatures might also be a slight help.
I paid for the most recent flash even though I was not having any problems for two reasons:
1. Inductive heating
2. Updated idle strategy - eliminates EGR operation at extended idle
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 6 Old 03-31-2008, 11:15 AM
ebusa's Avatar
I paid to have mine EGR turned off with an SCT X3!!
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #5 of 6 Old 03-31-2008, 01:05 PM
mrnecsteve's Avatar
They used to recomend replacement but have since issued proper cleaning procedures
TSB # 06-19-6 has been released with guidelines to clean and test the valve for proper operation. If the valve shows signs of excessive coking the root cause of the coking must be identified and corrected. Cleaning of the EGR bore and the intake manifold may also be required.
from: http://www.forddoctorsdts.com/articl...icle-06-12.php
mrnecsteve is offline
post #6 of 6 Old 03-31-2008, 05:48 PM
caissiel's Avatar
Idling my truck here in florida the water temperature goes down from 186F to 170/down lower if longer. I usualy never Idle it but it sure get colder as the Idle is extended.
2005, 6.0L, 6 Spd Std, 3.73 Rear End, F250SD, Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed, Max Energy programer by Hypertech, and Fuel Pressure Gauge. ScanGaugeII for 60 plus XGauges, and MPG. ELC Cat EC-1 Coolant, Pull a 39ft 15500Lbs 5th Wheel Camper Trailer. Mileage Avg is 20MPG, and pulling 12.6MPG.
caissiel is offline
