Truck Leaking!!!
Ok so heres the deal. I took my truck in for it's 60,000 mile service, not a bad thing right? That's what I thought, until I got home and found my transmission leaking all over my driveway! I took it back and the dealership said they had "overfilled" it,,,,nice. Not a big deal, I understand mistakes happen, so I didn't think much about it. About a week later I go outside and notice some small oil spots on the ground. I take it in and come to find out the cam sensor was bad. Once again, no big deal, things go bad. About another week goes by and guess what, I go outside and same thing, oil on the ground. I take it in, this time the left glow plug was leaking. Even after all this I still wasn't upset, mainly because my engine is still under the 100k warranty and it's not costing me anything, not even the deductible (dealership is good like that). Anyway I go out yesterday and same thing,,,LEAKING all over! I take it back and said keep it until it's fixed! The shop forman and service manager both come out and looked at my truck, I guess they wanted to make sure I new what a leak looked like...lol Anyway I ask the shop forman "do diesels just leak" and he says, "well by the book I'm suppose to say no, but in reality they do?" He said all the big three have the same problem? What gives, does this sound right or is this guy full of you know what???
I have an 04 that has never leaked
. Hope this helps.
I kind of knew the guy was full of crap. This is my first diesel, so I figured I'd just listen what this guy had to say. If it isn't fixed this time I'm going to head over to a different dealership. Thanks for the reply...
No problem. Keep us posted on what happens.
So at 54,000 my truck developed a rear main seal leak then at 58,000 a "valve cover" leak. I say it like that because I never saw the leak from the cover. It looks to be like the rear main seal again.
Lastley, had it fixed in early December with 100 bucks down. Two weeks ago I noticed it was leaking again but not as thick. Someone had mentioned that it could be just condensation running off from behind the block because of the temp changes and what not. Now it's starting to leak like a sive. And I'm heading to the dealer this Monday. For a 50,000 truck, If it didn't roll off the factory floor leaking then it better not be leaking now, at least not until I hit the 100K mark. My server order writer said "the "6.0' tend to leak for than other"....duhhhhhhhhhhhhhhhhhh whatever |
Have them put the dye in there and then look for leaks. Otherwise, they are just chasing their tails...
I second the dye. My truck would have been fixed the first time instead of 3 visits if they had used the dye the first time around.
They are using the dye, that's the crazy part. Each time they run it through they seem to find something new. We'll see what they have to say tomorrow,,,,I hope.
Update, just got off the phone with the dealership. They are pulling my motor and replacing every gasket/seal in it. Hopefully this fixes it this time, we'll see...
Wow pulling the motor ain't they energetic
