how high is boost - Ford Powerstroke Diesel Forum
Old 03-21-2008, 09:40 AM
lifetime member
how high is boost
on a 6.0, what is your boost on stock, and what is with sct on haul#$^^%#!@$# ? i am trying to compare
Old 03-21-2008, 09:49 AM
Dunno about stock, But my SCT on looney with my mods in signature, I hit 28lbs unless I am in overdrive, If I am in OD without hammering it enough to drop a gear I will hit 35lbs of boost... Hope this helps!
Old 03-21-2008, 09:50 AM
lifetime member
thanks for the reply
Old 03-21-2008, 10:14 AM
International Harvester
My boost is significantly lower that that. When I was stock I would hit about 28 psi when I was really getting into it.
Now that I have my SCT I only see about 22 psi or so when I am really getting into it.
Hope this helps.
Old 03-21-2008, 10:56 AM
This is odd for custom tunes especially DJ's. Most tuners are making less boost than stock unless you have head studs. My IDP tunes usually stay under 28 psi with a max of 30 to 31.
Old 03-21-2008, 10:06 PM
Well since I got my boost fitting in the right spot(should of tapped the elbow the first time) I can get accurate readings. Laying into it from a stop I am around 23-25. Hammering on it just enough so it wont down shift I have seen 28+.
Old 03-24-2008, 06:43 PM
my street file makes more boost then my looney,. I usually see about 36 pounds
Old 03-25-2008, 06:35 AM
I'm seeing 22-24 max. EGR turned off...
Old 03-25-2008, 06:59 AM
Hmmmmm...anyone know what boost pressure will set the "check engine" lite on a stock 2004 6.0 sd with automatic xmission?
Old 04-06-2008, 03:54 AM
lifetime member
i would like to know
